Garage door openers and Tesla's Faraday Cage
Discussion in 'Model S: User Interface' started by wcalvin, Nov 3, 2013.
  1. wcalvin
    wcalvin Member
    Seattle WA USA
    Anyone found a good solution yet for positioning the remote control, for those of us who cannot use the spotted area around the center rearview mirror? I ever tried placing it behind the nosecone.
  2. jerry33
    Texas
    You can't use Homelink? I don't even carry the remote anymore.
  3. teslasguy
    teslasguy MSP P#1117
    West Chester, Pa
    My home link only works from less than 5' from the garage door. Anyone know anyway to boost this range? My wife's highlander works from 1/2 block away.
  4. wcalvin
    wcalvin Member
    Seattle WA USA
    Not a Homelink: It's a underground parking lot with a gate halfway down for residents.
  5. Jason
    Jason Member
    DFW, TX
    Couple of quick things to try - put new battery in remote and re-program. I couldn't even get mine to program until I put in new batt, yet remote opened door, go figure.
    Make sure antenna on garage door is straight - I know it works with other car, but doesn't hurt to try.
    They (homelink) have intentionally been reducing range on their modules for safety reasons - within sight of door so you can see it, so as not to close it on someone, etc...
    and if your curious as to where the transmitter is located, I will attach pic, it is right next to frunk latch.
    Also this range challenge is with many new models of cars - do a google search 'how to increase range of homelink' and you will see many complaints, and even some modifications to extend the range of the homelink units.
  6. teslasguy
    West Chester, Pa
    What battery are you referring to?
  7. kendallpb
    kendallpb Model S: P 8061
    MD, USA
    Wow, mine works great, even aimed away (bouncing off other houses/cars). Not half a block away since the house is on a bit of a hill, so I couldn't aim it quite right, but mine works a lot better than yours.
    - - - Updated - - -
    Open your window and stick your arm out? Open pano roof and stick arm up? I'm serious about both; this is how I had to use EZpass, sigh....
  8. dflye
    dflye S Sig Perf 414, VIN 814
    Raleigh, NC
    My homelink garage door opener only pays attention to my Model S about one house before mine. Which is just barely before the Model S presents the list of nearby homelink receivers that it has been programmed to cooperate with.
    I really wish the range was greater (whether due to a SW or HW fix), so that I could push the button several houses up the road afore mine and ensure that the garage door was open fully by the time I was at the end of the driveway!
  9. teslasguy
    West Chester, Pa
    Sorry, I was referring to the drop down opener commands in the car. Not a separate remote opener.
  10. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Your best bet is to reprogram the Homelink at a position where you'd like the drop down to occur. Maybe at the top of your driveway or your neighbor's driveway along the way you come home. It's programmed to drop down where you program it, it couldn't care less where you garage door actually is.
  11. teslasguy
    West Chester, Pa
    I'm not as concerned where the drop down occurs as I am that pushing the drop down does nothing until I'm less than 5 feet from the door. I've tried pushing the drop down icon for my door at just about every distance from 60' until I almost touch the door with my front bumper.
  12. Jace_91
    Jace_91 Member
    Hollywood, FL
    I think Jason is referring to the battery in your hand held garage door opener. Has happened to me in other cars as well; garage door opener worked fine to open the gate but when I used it to program my home link it either wouldn't take or was very unreliable. replaced the battery in the garage door opener then reprogramed the home link and worked much better.
  13. donv
    donv Member
    Lake Jeanclia, OR
    I've found the HomeLink in the Model S to have considerably longer range than HomeLink I've used in other cars, for whatever that's worth.
  14. strider
    strider Active Member
    NE Oklahoma
    Our Homelink has been reliable. We also are able to use our regular remote from inside the car w/o problems. Our 2-year-old likes to push buttons and so he has become the official garage door opener and closer - since he's in a car seat in the back seat we just hand him the remote that came w/ the GDO. Works fine from the driveway - 10' or so away from the door.
    I did extend the antenna on the opener in the garage. You should see a bit of wire hanging down from the opener. I just stripped the wire and added ~2ft of light-guage wire in a loop and range was dramatically increased. I'll try to take and post a picture if that isn't clear.
  15. PhilBa
    PhilBa Active Member
    Seattle
    Agree with the advice to check the opener's antenna. Should be perpendicular to the vehicle. (OK, better said, it should lie in the plane that is perpendicular to line from the receiver to the vehicle - vertical is usually pretty good).
  16. Jace_91
    Jace_91 Member
    Hollywood, FL
    Its a parking garage so Im assuming he cannot adjust the antenna.
  17. paco3791
    paco3791 TMC OG
    Antioch, IL
    I have to say, as a non-tech package car owner, this was one of the things I was worried about, but oddly enough it has been a total non-issue for me. I clip my garage door opener to the sunshade, like I have on every other car I have ever owned, and it operates the garage door flawlessly, just like ever other car I've ever owned. not sure what it is, but for whatever reason the windshield coating has caused zero issues with my particular opener.
  18. DriverOne
    DriverOne Supporting Member
    Austin, TX
    No Homelink here either. I clip my opener to the side of the center cubby under the screen. Works great.
  19. Jace_91
    Jace_91 Member
    Hollywood, FL
    On a car of this price range that should not be an option; home link, driver profiles, automatic keyless entry should all be included. The others are bigger changes so I can see why there would be an up charge for them, but driver profiles are just a software update aren't they? and home link and automatic keyless are probably 1 sensor each. Sorry to get off topic.
  20. strider
    NE Oklahoma
    You've obviously never optioned a Porsche or similar "car of this price range." Hell you can spend as much on options on a 911 as you do for the base car. Options pricing and packaging are very contentious topics in all sorts of applications. Cable TV anyone? Buying a new house? You name it. Companies have to make decisions about how to package and price options. You're not going to make everyone happy.
