Garage door randomly opened
Discussion in 'Canada' started by Shaz, Sep 21, 2017.
Tags:
  1. Shaz
    Shaz Member
    Vaughan, Ontario, Canada
    Hi Everyone,
    Just wondering if anyone had experienced this, I took delivery of my MX this past weekend and when I got home i setup home link to auto open the garage door when approaching the house from the outside ( I did not enable the auto close feature). For the first couple of days it was fine, but then last night at around 10:30pm, I hear my garage door opening. I looked around and didn't see anyone, so I could only assume the MX had initiated the open command. Looking through the forums, some are saying it may be due to the GPS skipping around making the MX think that it's outside of the garage hence the open command. Needless to say, I disabled homelink for now and just use our regular garage door opener.
    Has anyone experienced this? If so, any tips on how to resolve this?
    Thanks.
  2. Phillip L
    Phillip L Gas Passer
    Owen Sound, Ontario, Canada
    I disabled homelink automatic opening because last year after several weeks away it did not open the garage door. Then when I brought up the icon to open the door I hit it, door did not open, hit it again and the door started to open, then it stopped just at the height of the top of the car and I scraped the top of the car (did not see it was partly down because I was backing in). I think I may have double tapped it as the door was opening, or something. Anyway, now I just use homelink like a regular garage door opener. It pops up on the centre console screen automatically as we approach the garage.
    BTW, I feel the same about AP. I use it very occasionally but don't trust that it is 100% reliable since it tried to keep going straight off the road when I was in the right hand of a passing lane that had ended. AP wanted to follow the straight dotted line on the left that signals the end of the passing lane instead of the right handed solid white line. Now I just use AP if I am rummaging around for something or doing something complicated on the centre console, since it drives better that a very distracted me in those situations.
  3. sakimano
    sakimano Member
    Ontario, Canada
    Maybe report these concerns to tesla with notes. And let your service centre know and maybe they can diagnose remotely.
    Could be someone is trying to rob you, not your car accidentally opening the garage.
  4. 12Pack
    12Pack Member
    Manchester, UK
    FWIW, in the UK the software (at least, mine) does not allow automating the homelink - just having it pop up when you arrive - perhaps precisely for the reason posted by the OP.
  5. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I've had no problems with auto-open / auto-close, except occasionally it doesn't even attempt to auto-close. That happens about once every week or two.
    The other glitch I've seen is having it trigger Homelink when it was a kilometer from home. It has no actual effect other than the "BING" sound. It's happened dozens of times, though not in the last few days so maybe they've finally fixed a bug.
  6. MorrisonHiker
    MorrisonHiker S 90D 2018.6.1
    Colorado
    When I first got my Tesla, it turns out that I programmed it to control the garage door at the same time that my neighbor was leaving their house. Then for a few days afterwards, whenever they would leave or come back, I would hear my garage door open since my garage door openers had actually learned my Tesla and my neighbor's remote at the same time. I cleared out all remotes on the garage doors and reprogrammed them all. Everything has worked fine ever since.
  7. Vip
    Vip Member
    United States
    That is crazy!! The possibilities of this happening!!
  8. Shaz
    Shaz Member
    Thanks everyone for your input. I'll definitely let Tesla know of this instance. I will set up homelink again but this time i'll just keep the auto open / close turned off.
  9. cmt489
    cmt489 Member
    North Vancouver, BC
    I had this happening in the beginning as well. We changed out our control unit on our garage door and it hasn't happened since. I think they get wonky with the homelink if they are even remotely compromised or a little older.
  10. patrick40363
    patrick40363 Member
    Cali
    I didn't have the problem but needed to address leaving the door open by accident. I changed to liftmaster openers that are wi-fi connected and have battery back-up. The door status can be accessed online anywhere you can get on the net and you can open/close when needed. The best feature is you can set the door to automatically close if you forget. It has a timer with various times. Mine is set to close in 5 minutes if left open and there is a button on the control to hold open too.
  11. brkaus
    brkaus Active Member
    Lots of possible explanations to the garage door opening. I doubt it was the car, but certainly a possibility.
    I personally would never allow the car to auto-open or auto-close. The reason is that the homelink protocol does not have an "Open" or "Close" command. It simply has a "Press" commend. So the car is tracking the state based on what the car thinks, not about the reality of the garage door positioning.
  12. Doug_G
    Ottawa, Canada
    This morning my Tesla failed to close the door when I left. Then it tried to trigger the door a kilometer from home. So that bug is NOT fixed.
    The current software is pretty flaky. It regularly "forgets" what the speed limit is, or that you're on a divided highway, which makes it impossible to use autopilot. That started happening two updates ago.
    I don't know why they keep having these bad regressions.
  13. mkjayakumar
    mkjayakumar Active Member
    Dallas, TX
    only have auto open enabled. Works flawlessly everytime when I approach my garage.
    I got used to it so much, when i drove my other ICE car the other day, as i drove into my driveway, I was perplexed as to why my door was not opening. It took me a minute to realize what is happening, fumbled around figured out where the home link button is and pressed it.
  14. sakimano
    sakimano Member
    Ontario, Canada
    Is auto close a new thing? I've only seen auto open which is what mine does.
  15. Doug_G
    Ottawa, Canada
    Yeah me too.
    No, auto close was introduced simultaneously with auto open.
  16. mkjayakumar
    Dallas, TX
    The problem with auto close is, how am i to be absolutely sure that the garage door closed? As I am driving away, I can only hope the door closed. The thought that it may not have closed, has forced me to come and check it, negating the very need for using autoclose.
  17. Doug_G
    Ottawa, Canada
    Personally I can see the door in my rear view as I drive away.
    Lacking that I would simply pause for a moment in the driveway.
  18. wayner
    wayner Active Member
    Toronto
    I back out of my garage and my auto close usually triggers when I back out by about 5m or so, just far enough to go forward around my circular driveway.
  19. d21mike
    d21mike Member
    Torrance, CA 90503
    Just got my car last week. I did not know there was a unique signal for OPEN and a unique signal for CLOSE. Do all garage doors work the same way? My concern was coming home and the garage door already open with grandkids around the door and then my car sends a signal that causes it to close on them before I can say skip. The other reason I did not want to use AUTO OPEN/CLOSE of the Garage is I read someone was setting it up and it close on his car. I kind of back out of my car slowly to not hit something.
    I do use it for the GATE when entering the community. However, since the exit GATE is right next to the enter GATE when I leave it also opens the GATE since the GPS is pretty close.
  20. wayner
    Toronto
    Technically I am pretty sure that Auto Open and Auto Close are misnomers as there are not discrete signals for open and close. What is really happening is that the car sends a "Toggle Door" command to your garage door opener under either the Auto Open or Auto Close. Doesn't your garage door have a safety "electronic eye" that causes the door to immediately stop if the beam across your door is broken (edit - these have been required for all openers made in the US since 1993)? If you don't then you should replace it - these have been standard for many years and are required for the "smart" garage door openers like the Chamberlain MyQ system.
