Garage remotes won't work now
Discussion in 'Model S: User Interface' started by fred z, Oct 3, 2014.
  1. fred z
    fred z Member
    Hey folks, gotta question somewhat related to above.
    I have a good hook up with Homelink on my car. But...all my remotes not worky! Any suggestions?
    thanks
    fred z:crying:
  2. fred z
    fred z Member
    Garage remotes don't work now that Homelink is operative
    Gents and Ladies.
    Is the fact that the MS is now homelinked affecting the normal remotes openers? Surprisingly...all three won't open or close the door
    any suggestions would be appreciated.
    thanks
    fred z:scared:
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    No it doesn't affect anything. We continue to use the garage remote in our other car, works fine.
  4. fred z
    fred z Member
    Does anyone else have the issue with normal remotes NOT working since the MS has homelink hooked up?
    Appreciate any help,
    thanks
    fred z
  5. Scott
    Scott Member
    SL,UT
    Have you tried resetting the computer, holding down the two thumb dials on your steering wheel? That generally is the default fix-all.
  6. Crispix
    Crispix Member
    San Diego
    You probably accidentally wiped and reset the main unit by holding down the learn button too long (it just needs a quick press to go into learn mode). You might need to pair the remotes again.
  7. Chipper
    Chipper Active Member
    Chattanooga, TN
    I think Crispix hit it right on the head. I recommend re-pairing the hand held remotes.
  8. UberEV1
    UberEV1 Member
    San Jose, CA
    Agree with Crispix as well. Went through a similar issue a few months ago when purchasing a keypad garage door opener. Check the manufacturer of the garage door opener and the color of the reset button (different colors denote different signal encoding types), then just use Google to find the correct programming procedure. Once you have that, it takes only a minute or two to reprogram each remote.
  9. brkaus
    brkaus Well-Known Member
    Austin, TX
    I would also add that the garage doors have limited memory. They will hold 5-6 remotes, at which point when you add another one the first one programmed will be dropped.
