JRP3
Hyperactive Member
Model S uses waste motor/inverter heat to warm the pack, probably not enough extra heat to provide much for the cabin. Remember one of the main benefits of an EV drivetrain is high efficiency, which means little waste heat.
Indeed, and subject as well to cold wind blowing over it at high velocity, not to mention splashing from sub-freezing water/salt mixtures.My sense is that the big hit comes from heating the battery, not the cabin. The battery is a big, broad sheet under the car that is constantly radiating any internal heat to the atmosphere.
I doubt there is any type of insulation that would be effective for a week, or even much more than a day or two.so what happens if the Tesla S stands still in winter for a week? Any insulation around the pack ? vaccum insulation would be ideal, very thin but efficient.
This is unacceptable to the majority of the population and we must find a solution if we want EVs to flourish.
Disagree. Ontario, Quebec, and many north Eastern US states have been gripped with -20°C or worse conditions the last few weeks. It does happen.The majority of the population will never make such a trip so the solution has a very small target market.
I awknowledge that driving 1,000km in a day is extreme but owning a car with a usable range of 200km in these winter conditions is unacceptable, IMO.
Resurrecting this conversation since I'm still shell-shocked from the 1,800km drive in -20ºC from PEI to Toronto. Fredericton to Ottawa is 1,000km and took almost 17 hours - 70% more than a comparable ICE trip.
But if it's a short trip there is also no reason not to, nor is there any reason to switch on range mode or keep the cabin heat on low. Short trip means you don't have to worry about range.There is no need to warm up the car for a short trip.
The real problem is that you have to be very careful about planning a trip where there is no charging at your destination. Particularly if you need to stay for a few days and make a trip or two during the time. You may have plenty of charge to get to and from your destination, but can use a ridiculous amount just getting the car warmed up for a short trip in the middle of your stay.
There is no need to warm up the car for a short trip. Switch on range mode, keep your clothes on and direct cabin heating to windscreen with slow fan.
They are two separate loops, so you'd either need two separate heaters. For practical use, heating just the battery pack would probably do wonders if you make lots of short trips in the winter. Could just use the seat heaters and wear gloves instead.I am curious about the battery heat in a Tesla, if a hydronic heater was used would you be heating the coolant that feeds the cabin only or are they combined to also heat/cool the battery pack?
That's what I've always imagined, just heating the battery quickly and unplugged pre heating.They are two separate loops, so you'd either need two separate heaters. For practical use, heating just the battery pack would probably do wonders if you make lots of short trips in the winter. Could just use the seat heaters and wear gloves instead.
