Did you get the RB rotors? One thing I would like to know is if the rotor hats are thicker than OEM PUP rotors and do they eliminate the step in the hub? That is one of MPP’s selling points for their rotor upgrades for the PUP brakes.
I can't figure out how to quote from other threads, but please look at the following link:
Vendor - Mountain Pass Performance Intro - Updates
@MountainPass seems to not agree with this method of brake upgrade. For those who have installed MS rotors on your 3 how did the ABS react?
I posted a response in that thread, but here is what I found in regards to the piston sizes.
M3 Base: 42mm
M3 PUP: 42mm
MS: 44mm
So the pistons are 2mm larger on the S calipers. However, that results in only about a 2% change in brake bias (to the front, assuming PUP Calipers to S Calipers). Track pads are roughly a 10% bias to the front (assuming installing on front only), and the 365mm BBK MPP sells is also about a 10% bias increase to the front (non-PUP).
So, long story short it should make no noticeable difference at all and less than other components on the market.
On my personal car with PUP I have experienced no negative ABS interactions over 1,500 miles of driving with the S Calipers (dry, wet, track, street, etc). I am working to outfit a non-PUP 3 with the S brakes to see how that performs to quell peoples concerns.
I believe that the proper formula would be caliper force is a function of piston area not diameter. In other words brake force would be proportional to the diameter squared in a given piston size. If you crunch the numbers I believe you get something like a 9% difference when you change from a 42 to a 44 mm piston. Still not huge.hmm... Where did you come up with the 10% bias change for a track pad swap? And where did you come up with 2% bias difference for the 2mm piston size change?
If you put track pads on the front axle and leave the stock rear pads there is a rather large (roughly 10%) increase in front bias, which many people (myself included) seem to be doing.
I think that estimate is DRASTICALLY understating the difference. Coefficient of friction doubles with a good brake pad, and once they are hot, it is even bigger. Also, a 10% change in bias is HUGE. Here is some data on coefficient of friction:
I agree a 10% difference in bias is large, but the alternative is to put track pads on both the front and rear axle to maintain the stock bias which, as far as I know, there are no track pads for the rear calipers (yet).
Ah, yeah that would be a big deal. What kind of times can these things run at VIR? Road Atlanta is my home track, but sadly, kids' activities have kept me from it since I sold my 968 (still have a 944T, though a bit apart as I am converting to an S to run lighter in the same class). The 968 had a Torsen style diff which would let teh rear get happy, which was scary as f*** going into 10A, at least the first time it happened.
Thank you for getting the piston sizes.I posted a response in that thread, but here is what I found in regards to the piston sizes.
M3 Base: 42mm
M3 PUP: 42mm
MS: 44mm
I'm busy working on some other components, but here is a teaser of the two-piece rotors.
The pictures are not showing. Just uploaded
The pictures are not showing. Just uploaded to TMC it seems to work better than trying to host them from a 3rd party.
So is the kit available yet?
X2
Very interested
