So you drove from Texas to San Diego in under 6 hours?
12) Don’t set your house on fire. The Gen 1 Connector stories are frightening!View attachment 419355
For what it is worth, I think we here in the forums are exposed to the “exception cases” a lot more than the “normal cases”.
There are 10’s of thousands of UMC Gen 1 units in the wild that are presumably working just fine.
I am not sure I would go as far as to recommend against their use. They might have a slightly higher anomaly rate than the Gen 2 units (due to the lower amps, the improved design, and the thermal sensors), but that does not necessarily mean they are unsafe to operate. It all depends on what your risk tolerance is.
Part of me kind of wants one so I can charge at 40 amps while on the road.
Good thoughts guys. Maybe I’ll swap out the Gen 1 and 2 for home use. That way I’ll move the risk out of my garage.
Normally 30mph charging is plenty
Yikes, I just bought one of these Gen1 UMC and have been using it as my permanent EVSE at home leaving it plugged in 24/7, and decided to use the Gen2 that came with my car as my mobile unit to keep in the car; fortunately I mostly charge at work, so I only use it to charge every now and then. Should I do the opposite and go back to using my Gen2 as the permanent EVSE at home and use the Gen1 as my mobile one instead?
I wish I knew about these "horror" stories being mentioned in this thread because that would've definitely deterred me from getting it. I was wondering why they were being sold for a really good price too, compared to the Gen2 since they charge at 40a.
I did not mean to scare anyone with this thread!
Anyway, once you understand the issues, you can figure out what makes sense for you and how many of the concerns actually apply.
I'll search around, but were they based on when the car was plugged in to the car, or just with the unit?
I'll give you one reason to keep using the Gen1 - when it's not charging it draws significantly less current.
Electric use of wall connector or mobile connector isolated
View attachment 419341 Just thought I’d share, I just moved and had a 14-50 installed. At 40A I’m getting 38-39mph charge rate with a Gen 1 connector. Extremely happy with this rate.
Well...as much as I hate these vampire drain sources...the 1.5W difference is honestly not that big a deal.
I wouldn't put too much stock into the inductive power meter readings. For example, the model you usedCompletely agree. That said a 20% regression is an odd thing and not normally something I'd expect Tesla to do without a reason. I wonder if that is the price you pay for monitoring the temperature at the connector?
