Gen 1 charger not working
Discussion in 'Model 3: Battery & Charging' started by clicketyclack, Dec 2, 2018.
  1. clicketyclack
    clicketyclack Member
    New Jersey
    I just got a gen 1 charger off ebay that was advertised as in working condition. It only came with the standard power adapter and not the 14-50.
    When I plugged it in I got an error that said "check power source" and the car would not charge. I have read that the gen 1 mobile charger should work fine, was that info incorrect?
  2. Kermee
    Kermee It's Not Easy Being Green
    WA, BC & HKG
    UMC1 should work perfectly fine although they have high failure rates if they were originally used at the higher 40A limit for a while. Does your UMC2 work fine on the same plug?
  3. eprosenx
    eprosenx Active Member
    Beaverton, OR
    Check to make sure there is no plastic or debris stuck in the end of the cord that goes in the car (does not sound like your issue).
    As others mentioned, it should work fine.
    Check to make sure the receptacle you are plugging into is grounded correctly. Trying with the UMC Gen 2 that came with the car is a good suggestion.
    Might be worth finding a Model S to try it with as well as a data point.
  4. GigaGrunt
    GigaGrunt Member
    Nevada
    Also check the incoming power with a meter.
  5. clicketyclack
    New Jersey
    the charger that came with the car works fine from the outlet. It must be defective, I started a return. Thanks for the help guys.
