Gen 3 charger not charging after outage
I purchased a Gen 3 charger and had it installed on the Controlled Load 1 circuit so that I could charge the car overnight when off-peak rates kick in about 12.30am and turn off at 7am. In Australia, electricity only runs through that circuit during these times.
Unfortunately, the charger does not start charging when the power goes on ... just gives the blue light (communicating with vehicle). So, if I want to have a full charge the next day, I set the alarm for 1am, get up and plug it in. If it is already plugged in, I need to remove the plug and replug it in to start it charging.
I have communicated with 5 Tesla people so far over the past 2 months with no resolution to the problem.
One Tesla person told me that the Gen 3 charger cannot start recharging again after a power outage.
Apparently, it needs to be continually powered.
This would be a problem if an outage occurred, and you thought that you would wake up to a charged car.
I did try scheduling it to start at 1am, but it didn’t work.
Does anyone else have the same issue? Does anyone have a solution?
