I’m going to guess soon Gen3 Wall charger will have that capability with the WiFi connectivity.Wish we could do this from the app (change amperage)
"soon"I’m going to guess soon Gen3 Wall charger will have that capability with the WiFi connectivity.
Yeah, cable is definitely heating, it's probably at least 75C rated, like the main terminals.I've notice that my car shows 229 - 230 volts when charging. I decided to see where the losses are, and determined the primary issue is with the relatively thin 18' cord on the Gen 3 HPWC. The cord on my JuiceBox is much bigger. In hindsight, I wish I got the 8.5' cord or another JuiceBox.
237 volts at the breaker (4 gauge wire).
Tesla reports a 9 volt drop. Assuming both are accurate, where did most of the 9*48=432 watts go?
Here it is... Ambient temp is 102*, wire is 125*. That was just 10 minutes, I'm sure it hadn't reached steady state yet. Sigh.
I'll take some measurements tonight or tomorrow. I usually don't run into issues when I'm only charging 10-15%, though. My car will probably only be around 65% so I might need to drive it around a bit to force a longer charge, or wait to charge it Sunday or Monday and take temps then.My entire cable gets quite warm, so the issue is with cable. I've emailed tech support twice, but haven't gotten any response.
Can someone else measure their cable temp? A handheld IR thermometer works well for this also.
Here are my readings with an IR thermometer.My entire cable gets quite warm, so the issue is with cable. I've emailed tech support twice, but haven't gotten any response.
yeah, next time. Just frustrating having to dial back.Try backing it down to 40A
... Hard to tell if this is firmware of hardware related. Frustrating.
I had the breaker replaced 2 weeks ago as a precaution.It is, but from the look of it you've got some resistance building. How is the breaker?
On the previous firmware it would drop to below 6A and then stop charging all together. On the current firmware, it seems to continue charge at 24A but not charge at 48A. Probably programmed to not do so at certain temperatures.Cool so it reads the cable temp and decides to throttle. If you leave it connected does it ramp back up eventually?
