ElectricIAC
Good-Natured Rascal
When our sub-breaker went on the fritz we found the 14-50 receptacle was getting scalding hot at full power before tripping which made everything connected to it hot as well.
Run at 40a and see if it remains level then.FWIW I just went out to my Gen 3 charger, which I’ve stepped down (from inside the car) to 36A because I get the overheating error at 48A too. My car has been charging at 36A for over an hour now and the cord isn’t even warm. This whole thing is such a mystery but at least I’m not alone in experiencing it.
I tried the same thing and NO difference with the overheating. The actual overheat problem is nonexistent, it's showing overheat but it really isn't. That's why tesla said we can continue to using the wall connector without worries.Tesla support told me this is a known issue and they are mailing me a new one, so we'll see with that.
I was thinking though, My cord was coiled pretty tightly on the charger, as I have an 18ft cord and need basically 4 feet. I wonder if this has anything to do with the heat not dissipating. I loosened the wrapping of it so it hangs quite a bit lower now, so we'll see what happens when I charge next
I don’t disagree. That’s the trouble with these things though, you have to run down every connection point to make sure you’ve done your due diligence.the last 3 days I've been having over heating issues. It was running perfectly fine for the last month at 48 amps. I bumped it down to 40 to see if that helps. Still stupid though as its down to 65 degrees outside right now, and it worked at 48 amps in the 90's
I’m getting back to this thread really late—sorry about that.Run at 40a and see if it remains level then.
Huh. So at least they are having different reduction ratios that we can use to diagnose the different problems. For anyone who hasn't seen these yet, here are the telltale indicators:My Gen 3 would overheat at 40A too, dropping the charge to 20A, so the firmware clearly just cuts the rate in half.
I’m responding to this thread because I see you have at least seen that #3 issue discussed. I think my car has that issue now, unrelated (I guess?) to my prior HPWC issue.3. Reduction by an increment of 16 amps indicates one of the modules inside the car's internal charger has failed. (This applies to the newer 32 and 48 amp chargers, not the older 40/80 chargers.)
The Tesla SC told me not to worry, saying "it's normal". Well I am an electrical engineer and if a cable gets this hot, I do worry.
