Gen 3 HPWC 48amps
HPWC issues?
  • Have gen 3 HPWC - use daily at 48 amps - no issues.
    Votes: 14 46.7%
  • Have gen 3 HPWC - use daily at 48 amps - some issues.
    Votes: 2 6.7%
  • Have gen 3 HPWC - use daily at 48 amps - constant issues.
    Votes: 2 6.7%
  • Have gen 3 HPWC - use daily at < 48 amps - no issues.
    Votes: 10 33.3%
  • Have gen 3 HPWC - use daily at < 48 amps - some issues.
    Votes: 1 3.3%
  • Have gen 3 HPWC - use daily at < 48 amps - constant issues.
    Votes: 1 3.3%
  • Total voters
    30
Petrlol
399
537
Ohio
I've been contemplating getting a HPWC for 2 years now, and frankly the posts here an on Reddit are terrible for the 3rd gen.
All I see is overheating, reduced charge rate, flashing red lights, Wi-Fi provisioning issues, bad batch that needs replaced, caused by firmware, etc...
How many people here use the gen 3 HPWC daily at 48 amps and have 0 issues?
Reactions: mswlogo
GeezerSquid
Still a Geezer & Still A Squid
Jun 17, 2020
85
113
Baton Rouge, LA
I had one installed and had early issues. But it turned out that I had not followed the installation procedures. I failed to notice that I had to "Commission" the wall connector. After I scheduled a mobile service. They called a day after I made the appointment and told me to connect my wall connector to wifi so it could be checked and updated. That night it charged all night at 48 amps and has continued to do so for the past month or so.
Reactions: E-curb and Petrlol
UncleCreepy
169
270
Lunenburg, ON
I haven't had any real issues other than that the charging cord gets pretty hot, even more so with direct sunlight on it.
The amperage always stayed at 48 A though, regardless of the firmware version.
I'm a happy gen 2 HPWC user now.
mswlogo
5,965
4,572
MA, NH
I saw all the issues so I found a new Gen 2 on eBay. $30 over list. I lucked out because many sell for $700 to $900. I also wanted the 24 ft cord.
Reactions: Petrlol
pt19713
705
845
Delaware
Still waiting patiently for a long-term fix since June 30...
Reactions: Petrlol
Srad600Volt
290
184
Southern California
I have one on a 50A circuit, so it's running at 40A, but it has been flawless since day one. Not a single error. I seem to be in the minority though, my buddy got his MY a few weeks before me and his charger is giving him the three blinking red lights a lot.
Reactions: Petrlol
toneman82
41
17
Phoenix
I replaced a 5 yr old gen 1 having connector issues with a gen 3. No issues at all with a 50A circuit charging at 40A. This is in an extremely hot garage (often 105F) in Phoenix in summer. The cord is marginally warm, not hot. Though I did have the garage open one time and the sun was shining on the cord making is really hot. But still no problems charging. Had FW .58 from the factory. I believe it has upgraded since then, but I can't see as the upgrade broke the charger web page (see other thread on this).
Reactions: Petrlol
Petrlol
399
537
Ohio
So not as many responses as I'd hoped for but 12/16 no issues and 4/16 some or constant issues.
25% issue rate isn't exactly great...
Thanks for those who provided feedback!
mcorf
258
123
Campbell,Ohio
I have 2 with no issues.
Petrlol
399
537
Ohio
There are other manufacturers that charge at 48A if you’re not thrilled with Tesla as a choice. ChargePoint Home Flex is an option
Thanks,
I'm just going to chill with the mobile connector for now I suppose, maybe wait it out to see if it gets better, or get a gen 2 on ebay if not. Don't really want to go 3rd party charger.
mrbloons
54
110
Grand Rapids, MI
I have the Gen 3 HPWC, on a 60 amp circuit and have no issues, although I usually dial the charging speed down to far less than 48A because I rarely need to charge that fast. The only time I’ve charged at 48A was when I was driving around town a lot right before a long trip, but worked fine charging at 48A for well over an hour. Otherwise dial it down as to not stress the wiring unnecessarily. If charging at night 48A is kinda overkill.
FredMertz
310
359
Westchester, NY
Is there a longevity or operating benefit to going lower than 48? I never let the car get much below 70%, so charging speed is never really an issue, so I'd see no harm lowering the rate if it will help in some way.
Mokuzai
664
3,555
Valencia, CA
I have two Gen 3’s. Each hooked up to a 50 amp breaker however if both were going at 40 amps it would be too much for my sub panel. So even though I currently have one Tesla out of an over abundance of caution I have one set to 24 amps and the other set to 16 amps.
Once WiFi balancing is enabled I’ll put both on 40 amps.
No issues.
Reactions: Petrlol
