I've got a Tesla Model Y charging using the mobile connector at 32 amps + NEMA 14-50 and a Jeep Wrangler charging using a standard 120V outlet which used to require 12+ hours to fully charge. Felt that it is time to do a much needed upgrade. Originally the electrician quoted $3000 for the parts and labor to run it across the garage... I thought that was too much so decided to do it myself with the help of a family member. Note... I'm not a licensed electrician, this stuff can really hurt you if you don't know what you're doing.
Gen 3 wall connectors... 1 with Tesla plug and 1 with J1772 plug
This was configured as a 40A circuit off a 50A breaker. A new circuit was run using ~30' of 1/2" EMT conduit and 8 AWG cable from home depot from a new subpanel that the solar company installed in my garage. Some wiring from the solar circuit had to be modified to accommodate (new ground bar was added, not pictured). Also bought a conduit bender to do a few 90 degree bends.
Conduit and wire was run above the cars in the 2-car garage into the other side of the garage. Template from the wall connector was used to drill the mounting holes
Base plate mounted and the wires secured. This was 2x 8AWG hot cables (120v each) and a 10awg ground cable (green).
Lastly push the main body of the wall connector on secure the 4 screws and we're finished!
Jeep is happily charging using Tesla Wall connector
I was also surprised that the quality of Tesla's J1772 connector is much, much better than even public charging stations and most of the J1772 connectors out there. Its very well made. This J1772 Wall connector can also charge your Tesla... if you use the J1772 to Tesla adapter that came with the car. I did just that, to test the current and charging speed lol.
Task # 2 : Replace NEMA 14-50 plug with Gen 3 wall connector (i always charged my MY using a wall connector at 32A)
NEMA 14-50 uses 2 hot, 1 neutral and 1 ground and since the Wall connector uses 2 hot and 1 ground, one of the wires wasn't needed.
I found that the electrician used a punch out located low in the existing panel, and my OCD self wanted the wall connector higher up the wall. Luckily, the Wall connector is to be installed in my garage right behind the breaker box so i just had to find a relatively safe place to punch a new hole, so i picked this spot about 12" higher (feel free to let me know if i completely chose the wrong spot).
A hole was drilled in my panel using a step drill
Also drilled a hole thru the drywall in my garage.
To be continued
To be continued
