Hi All,
We own a model Y for close to one month with no charging issue up until last night (6/28). Gen 3 Wall Connector stopped charging due to overheating (3 red blinks) fault code exactly 30 minutes after initial charge in three separate occasions (at 12:30 AM, 8:20 AM, and 8:50 AM). No issue charging with regular mobile 110V plug. Called Tesla support and was told to contact electrician / installer to make sure that proper conduit and wiring were installed before calling charging support at 510-249-2490.
Electrician came and checked to make sure all connections were secured properly and called charging support, Was told that the new firmware would fix this issue. My old firmware was 0.8.4+g8984eea7a4b342 and the new firmware is 0.8.54+g46f395de1d5760. As per tesla's request, I waited for 2 hours after the firmware update before recharging the car. if this doesn't work, tesla is going to send mobile service to replace the charger. Will keep you posted.
