Germany has the right idea...
Discussion in 'Energy, Environment, and Policy' started by scaesare, Jun 2, 2014.
  1. scaesare
    scaesare Well-Known Member
    NoVA
    I wonder what their generation vs. usage is:
  2. Cottonwood
    Colorado
    Let's be generous and call those 250 Watt panels; there are 60 of them, so that is 15 kW DC. If you put that into the model at PVWatts Calculator for Hamburg Germany as the location, then you get an annual output of a little more than 12,000 kWh/yr. At 333 Wh per Rated Mile, that is an annual output of about 36,000 Rated Miles per year or at 150 Rated Miles per Supercharger Visit, that is worth about 240 Supercharger Visits per year.
    In Colorado, the annual production would be better. The same size array in Denver would produce about 22,000 kWh/yr, about 67,000 Rated Miles per year, and about 450 Supercharges per year. That is still only about 1.25 Supercharges per day.
    It takes a lot of panels and area to support the energy use of a Supercharger!
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
  4. Whitebird
    Whitebird New Member
    Michigan
  5. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Kind of funny they are all American cars...
  6. purplewalt
    purplewalt Active Member
    Dallas, Texas
    I noticed the same thing.
    There is a British Vauxhall version of the Volt (Ampera as I recall) sold in Europe, but it has a different grille.
    Probably not too many Tahoe SUVs and extended cab GMCs in Europe.
  7. rsanchez
    rsanchez Member
    Arizona
    I was thinking that was wayyy too many American cars for Germany..
  8. tezco
    tezco Sig P85
    Colorado
    Of course, in Boulder the annual production would be only + or - 6,700 Rated Miles--up to the point that our nortorious winds ripped that array right off it's base...
  9. MarkR
    MarkR Member
    N. Scottsdale, AZ
    #9 MarkR, Jun 2, 2014
    This solution is said to be on the market by a Scottsdale-based solar company owned by a Tesla Roadster owner. No . . . you can't drive with the solar array open!
  10. No Tailpipe
    No Tailpipe Member
    Eden Prairie, MN
    What the?!? I'd love to see it closed...can't imagine what it's like to drive with a large center post.
    It looks like something from the movie Men in Black when open.
  11. smartypnz
    smartypnz Supporting Member
    Monterey Peninsula
    Aren't there less expensive sun shades on the market?
  12. scaesare
    NoVA
  13. Mookuh
    Mookuh Member
    I doubt that's in Germany. EVs are a rarity here and have barely seen any work related or that were not owned by a utility company. And as others suggested, the car mix doesn't look very German either.
