agilmore915
Ordering Charger Port FOB
Hi Lolachampcar,
Thanks for all the work on this. Is it possible to order one of the FOB's?
Andrew
Hi Lolachampcar,
Andrew
It is the Proximity signal that tells the EV to stop pulling power from the EVSE.
https://code.google.com/p/open-evse/wiki/J1772Basics
Thank you to-
George lee
FatSal
Owner
FluxCap
Anyone that asked for one over four weeks ago (before I went on vacation) and have not received it please post or send me a PM and I will follow up.
All those that have asked recently, I'm back on it and should have another batch out within a few days.
FYI: Assembly instructions are back on post #246 (thread page 25). @invisik: I used my largest jeweler's screw driver to gently pry one side open, and then the other. The spoked wheel needed a little pressure to get it properly seated in it's recess so that the rest of the parts sit low enough to stay in proper position relative to the two centering ridges on either side of the case. Once they were in proper position the case will close, but it does take a bit of pressure to squeeze it closed.What's the easy way to pop it open to take the paper out under the battery? I usually end up breaking a few of the tabs off and then it never stays together
-m
