Getting the Sirius/XM radio code from a JVC unit
Discussion in 'Roadster 2008-2012' started by Timbrewer, Aug 2, 2018.
  1. Timbrewer
    Timbrewer Roadster Signature #29
    Greenbelt, MD, USA
    Apologies for not finding the answer in thread searching...
    I'm wanting to activate my Satellite radio in the JVC unit in my 1.5 Roadster. I have the manual and when I attempt to get the code on the display it doesn't seem to work. I thought I did this when I first bought it 5 years ago.
    Has anyone had success in getting the radio code to display on the JVC?
    I think the code is also on a label on the unit somewhere too, may have to go into Tesla service center anyway for a bad tire pressure monitor warning so could have them look at this tooo..
    Thanks!!
    Tim
  2. cgrubbe
    cgrubbe Member
    Columbus, OH
    Don't have a roadster, so this might be totally wrong, but typically if you go to channel 0 on a satellite radio it will display the radio ID. Done this on many radios, both XM and Sirius over the years.
  3. da2ny
    da2ny 2010 Roadster Sport Twilight Blue #913
    Beverly Hills, CA
    I believe I used the "Band" button to bring up the Satellite band, then I held down the "Band" button and that brought up a list which included the radio number. I scrolled down to that and hit the "Enter" button.
  4. pwwojcik
    pwwojcik Member
    Maryland
    It took me a while to find this but I fiddled a while and eventually got it. It is something like this:
    1) Tune Sirius
    2) Press menu to get the AV menu
    3) Choose "Setup"
    4) Choose "Tuner" SiriusID might show up or be a menu option
    Take a look on page 93 of this manual: kd-nx5000 instructions - JVC USA
    Cheers,
    Paul
  5. Timbrewer
    Greenbelt, MD, USA
    Thank Paul,
    I think I know how to get to the setup, it never occurred to me to select "Tuner" :)
    I have this PDF manual, thank for posting it. There's so much info in it and I find it rather a challenge to get what I need from it :)
    Tim
  6. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    There are two different JVC units that were available in the Roadster; a normal radio and one with navigation. Which one do you have?
  7. slcasner
    slcasner Active Member
    Sunnyvale, CA
    The KD-NX5000 manual is terrible. It's very hard to find many of the key little secrets one needs to know.
  8. Timbrewer
    Greenbelt, MD, USA
    I have the one with Nav.
  9. supersnoop
    Pflugerville
    That's the KD-NX5000. There are actually two different "satellite" modules; XM and Sirius from before they merged. I don't know which one was included with the Roadster, but my bet is Sirius based on the wiring. (I added mine later)
    For XM: Use the "AV" button to set the radio to Satellite, and then tune to channel 0. The ID will be displayed.
    For Sirius: While displaying AV on the screen (not maps or phone), push the menu button, select Setup, and then select the Tuner option. "SIRIUS ID" should be the third option.
    The other JVC head unit is KD-R900, which does not have navigation. To get the Sirius ID on this unit, push and hold the menu button to get into the setup menu. Select Tuner and then the first option: Sirius ID. (I pulled this unit out of my Roadster and installed it in my other vehicle)
  10. Timbrewer
    Greenbelt, MD, USA
    Got it today, what a wacky interface!:)
    Thanks again Paul!
  11. Timbrewer
    Greenbelt, MD, USA
    The Sirius direction worked for me today, soon will have more music choices and get to see if the Sat radio reception is good or not!
    Thanks Supersnoop.
