S-2000 Roadster
#1244
That's basically correct, but I think it's important (again) to consider the safety ground.My understanding, and someone can correct me if I'm wrong, is that while a circuit breaker detects excess current, a GFCI detects imbalanced current: more current going out than coming back, which means there is leakage to ground. Also, it is my understanding that a GFCI will trip much faster than a circuit breaker.
At a minimum, you need two contacts to make a circuit, but you'll note that high-powered electronics generally have three contacts. Technically, one of the two blades on a 120 VAC plug is neutral, which is basically the same as ground. That neutral contact should be carrying 100% of the return current going back to the socket. The safety ground is there to conduct current (hopefully instead of your body) when there is a fault in the high-power device. If the device is working correctly, there should be 0 A flowing through the safety ground contact. The GFCI circuit looks for 0 A, plus a small threshold for slight imperfections, and trips long before the breaker if it finds current on the safety ground.
In other words, whenever there is more current going out than coming back, this imbalance is between the hot and neutral contacts. But, according to the rules of electronics, there must always be a circuit, so the safety ground ends up passing the difference in current. GFCI can detect an unexpected current in the safety ground and/or an imbalance in current between hot and neutral. Note that another possibility for an imbalance occurs when there is another path for ground current, such as through the 'earth' or a body of conductive water. That's an unsafe ground, and would not show up in the safety ground current measurement, but would still cause an imbalance.
That Xebra LiFePO4 appears to be a 3,000 W charger! I'm surprised that you can even safely plug that in to a standard 120 VAC receptacle, considering that the highest ratings are 12A/15A and 16A/20A. I was under the impression that an 1800 W hair dryer was about the most powerful thing you can plug in at home (maybe 1920 W at the extreme). Where, exactly, do you plug in this Xebra?As for the Xebra, it has an aftermarket LiFePO4 battery pack and matching charger. It draws 25 amps at 120 volts. The EV Porsche, however, (which was sort of operational for a month before it went in to another shop to be fixed from the original botched conversion job) charges off an RV-style circuit: 240 volts, 50 amps, though my understanding is that it only draws 40 amps. IOW it draws the same as the Roadster when the Roadster is on the UMC. In fact, I had the circuit installed for the Porsche. It was fortuitous that it's perfect for the Roadster as well. The Porsche, like the Xebra, plugs directly into the wall and that connects directly to the charger. But unlike the Roadster, neither the Porsche nor the Xebra can plug into anything but their respective design circuits.
By the way, there is a very specific reason why all of these 50 A chargers only draw 40 A. Electrical codes state that normal use should only pull 80% of the rated current. I learned this from a certified electrician at Lowes, as well as from advice here on this forum when I installed my own NEMA 14-50. If you do the quick math, 80% of 50 A is 40 A. In fact, every one of the available current presets on the Tesla Roadster is 80% of a standard breaker. The only exception is that the 90 A Tesla HPC should be able to draw 72 A instead of only 70 A, but the limit is the rating of the connector on the Roadster itself.
Another thing to note is that the plugs and receptacles have current ratings, too. So, that NEMA 15-50 connection is only rated at 50 A maximum. If you boost the breaker and set the Roadster to pull 70 A, then everything will be fine except the plug and socket, which might catch fire! Getting back to your Xebra, I'm surprised that you can plug anything in, since standard extension cords and 120 V sockets are not really rated for 25 A.
