Give Me An Option for Walk-Up Unlock!
Discussion in 'Model 3: User Interface' started by gizmoboy, Jun 19, 2018.
  1. gizmoboy
    gizmoboy Member
    Rancho Palos Verdes, CA
    My wife generally loves her 3, but she continues to have 2 complaints.
    First and foremost, she’s spitting mad that they took away walk-up unlock. The “tap the handles to unlock” is a major regression in her eyes. Having to hit the handles to get the charger port to open up for her is a daily nuisance.
    this is compounded by complaint #2, which is a recent string increase in the Phone Key not working reliably.
    I can see how walk-up unlock may not be for everyone, but they should definitely make it an option like walk-away lock is.
  2. bkp_duke
    bkp_duke Active Member
    San Diego, CA
    Buy an S?
    Seriously, they have to reserve some features for the high end to distinguish the product lines.
    • Disagree x 6
  3. SDKoala
    SDKoala Model 3 LR RWD
    San Diego
    I'd hardly call unlocking the car when the phone comes near a "high end" feature. It was already present on the 3 then disabled. Are you are getting what OP is saying confused with automatic presenting of the handles like the S? Regardless, an enable/disable option would have been much better instead of taking it away completely.
  4. johndorian
    johndorian Member
    GTA
    Cars that cost $40 thousand (CAD) less have keyless entry, why do they need to "reserve" this feature for the S again?
  5. bkp_duke
    San Diego, CA
    Keyless entry is not the same was walk-up auto unlock.
  6. jsmay311
    jsmay311 Member
    Chicago suburbs
    If the Model 3's existing keyless entry systems worked as advertised, this would be a moot issue, since the charge connector is supposed to unlock when an authenticated phone is within range and the button on the charge connector is pressed. (see Page 109 in the manual, under "Stopping Charging" https://www.tesla.com/content/dam/tesla/Ownership/Own/Model%203%20Owners%20Manual.pdf )
    So, really, "walk-up unlock" in this case would just be a work-around for having a keyless entry system that works. (I.e., a key fob.)
  7. Skotty
    Skotty 2014 S P85 | 2020 3 P19"
    Kansas City, MO
    Why did they remove the feature?
    Also, I'm a little confused. You have to touch the handle to open the car door, so why does it matter? Or are we only talking about the charge port door here?
  8. diamond.g
    diamond.g Active Member
    Moyock, NC
    People were complaining that the car was locking and unlocking while in the garage . Walk up unlock was the default option initially. Maybe they will add it back as an option when they offer a key fob again .
  9. Scrutmonkey
    Scrutmonkey Member
    They should probably have an option for it again in the future, then break it down into two parts:
    Options:
    Auto unlock for doors
    Auto unlock for charge port only (I'm sure some of us would love this option)
  10. Knightshade
    Knightshade Well-Known Member
    NC
    Man, if only the car had some way of locating its position....you know...globally...with some kind of system... so it would know when it's "home" and not keep doing that.
  11. diamond.g
    Moyock, NC
    Really the issue is anywhere you park and stay too close to the car. As far as I know there are only two other cars that actually unlock as you approach the vehicle (the S and X), others either have a sensor in the handle (VW Kessy) or make you press a button on the door handle (GM) before the car unlocks. Of course I could be wrong, I just haven't seen any that flat unlock without physical interaction.
  12. gregincal
    gregincal Active Member
    Santa Cruz, CA
    If you press the button to unlatch the charge port, it needs unlatch if the phone key is present, whether the car is locked or unlocked. There’s no reason for an option and no reason why Tesla can’t implement this. I keep expecting them to fix this obvious bug with each release. If your only reason to want walk up unlock is to work around this bug, I think you’re focusing on the wrong thing.
  13. dsvick
    dsvick Active Member
    NE Ohio
    Why would you not want your car to lock and unlock in the garage or driveway?
  14. Knightshade
    NC
    Because my garage already has a locked door on it and I don't want my car door locks cycling every time I walk into or out of the kitchen that is right next to said garage?
    But yeah- this overall seems a case of Tesla having overthought the entire system.
    My 10 year old lexus I use a credit card key. When I walk up "near" the car, but only within a couple of feet, if it's dark it will turn on the door/puddle lights, and if I touch the door handle it unlocks the door. Ditto if I touch the trunk release at the back by the trunk.
    This works flawlessly 100% of the time, without need of a fob, or my phone, or ever taking anything out of a wallet/pocket.
  15. TT97
    TT97 Active Member
    Los Angeles
    Our garage is directly below the master bedroom and right in front of the stairs so walk a few feet from the garage anytime I go up and down - never have any issues with the car waking up walking by or being in the bedroom.
    However, I would like it to stay unlocked as well, I have had multiple times I needed something in the car and went to get it, only to realize I didn't have my phone (or card) on me.
  16. diamond.g
    Moyock, NC
    Yeah RFID probably would have been cheaper than NFC and Bluetooth.
  17. smak
    smak Member
    NorthHollywood, CA
    When the complaints came in about people in their house so close to their car that it unlocks, they should have just made it a toggle.
    I want it to unlock when I'm 10 feet away.
    I am in a condo, I'm not close to the car.
    If I ever buy a house, and I'm 5 feet from my car, I could just toggle it off.
  18. diamond.g
    Moyock, NC
    It was a toggle. It should have been defaulted to off rather than taken away.
  19. Darscot
    Darscot Member
    BC
    How about walk up unlock with the options, on, off and on except when parked at home. They already have the gps location for Homelink.
