Coward
So what's causing the warming? Cosmic Rays that we somehow cannot detect but are also heating the atmosphere?
Coward
There is warming, no doubt.
So by that graph the sea ice extent is the same as it was on this date in 2012? Kudos to you sir
So arctic sea ice extent is unchanged over the past 7 years, even while CO2 has gone up from 400 to 415? Oh wait.............
Wait, how did this happen last summer?
Arctic fox astounds scientists by trekking 2,176 miles in 76 days — from Norway to Canada
Couple of points to unpack.
#1. The amount of CO2 humans add each year to the atmosphere is real but small compared to natural emissions. CAGW theory makes the (incorrect) assumption that natural emissions and adsorption are always in balance. So then any increase is by default caused by humans.
#2 I do accept that CO2 has a small warming effect. The effect is more pronounced when going from lower levels like 300ppm to 400ppm. The effect gets smaller as the concentration increases. In other words going from 400ppm to 500ppm will cause less warming than 300-400ppm.. This is well understood. But observed ECS has been calculated to be much smaller than that predicted by IPCC and the climate models. Why is that?
#3 Probably because: Forcings do not equal warming. The earths climate is dynamic, chaotic, and has multiple feedbacks all tending towards equilibrium. Just one example: increased CO2 causes greening of earth, and therefor higher carbon sequestration.
#4 Another assumption CAGW adherents makes is that any warming above some magical number they pick is defacto harmful. It may very well be that the CO2 humans pump into the air has warmed us 1C or so, but that that warming is net beneficial vs harmful. And since the Earth is due for another cold period/ice age, that 1-2 C may actually help mitigate some of that cold. Cold is much more difficult for terrestrial creatures to deal with than warmth.
When I was in school a lot of the stuff they taught me turned out to be proven wrong years later. That led to a lot of critical thinking on my part.
I appreciate your debating on the merits of the arguments instead of attacking the messenger. That sharpens both sides of a debate is is really the only way to gain understanding of complex issues.
Even IPCC does not agree with you on that. Pretty extreme position, but OK.*sigh*
#1 NO.... Anthropogenic emissions are ~100% of the rise. The fact that they're a small fraction of the natural exchange is irrelevant. The best analogy I've seen to explain this is the train station analogy. You have a train platform in which 100 people arrive and 100 people depart every 10 minutes (because the train can only accept ~100 people). Now 103 people are arriving. The train platform is going to get crowded... those 3 extra people are not 3% of the cause of crowding. They're 100% of the cause.
I was not ingroning it. Albedo is a tricky subject. Water vapor as you know is am much more powerful greenhouse gas than CO2. But clouds can both warm and cool the surface, and we have no good models that can even explain water vapor cycles. IPCC just ignores them.#2 You're ignoring other feedbacks that begin to kick in like albedo and H2O. The tiny increase in warming from Earth orbital shifts is also limited but it causes an increase in CO2 which further amplifies warming. There are tipping points at each level which accelerate warming. CO2 from 400 => 450 may have a smaller effect that 350 => 400 but the decreased ice cover BECAUSE CO2 is now 450 means that the OVERALL effect is greater.
That physics your side like to use does not describe a complex system. Only one aspect of it.#3 Forcings DO equal warming overall. It's buried in chaos but 1w/m^2 more is 1w/m^2. It's physics. CO2 levels are still rising.... obviously any increased sequestration is being overwhelmed.
This statement is just completly wrong. The earth experienced major Ice ages in the past (carboniferous and late ordovinian) when CO2 levels were well about 2000ppm#4 CO2 drives glacial periods. If CO2 is >300ppm a glacial period is physically impossible absent a large injection of SO2.
Well, IPCC is pretty confident that we have caused at least half of it. I don't believe that myself, but OK, let say that is true. Since 1880 the GMT has gone up by 0.8 C, that means that natural variation caused a little less than 0.4 C, and we caused a little more than 0.4 C. Another way to state this: Without any contributions from man (CO2) the GMT went up ~0.4 C. What is your explanation for that rise?What percentage of the observed warming is caused by CO2? If it's not ~100%... what's causing it? Like you stated we should be in a cooling trend.....
Hard for some to accept reality.
There is no climate change
