Glovebox phantom opening?
Discussion in 'Model 3' started by SDM3, Jun 13, 2018.
  1. SDM3
    SDM3 Member
    SD
    My glovebox randomly opens by itself while driving. Anyone else have this problem? I guess it’s not completely random because it seems to be associated with hitting a bump or quick acceleration. It also seems to happen on hot days. I tried taking everything out of it (it was just owners manual and registration) but that didn’t help. I’m trying to schedule a service visit but thought I’d see if anyone else has solved this.
  2. RubberToe
    RubberToe Supporting the greater good
    El Lay
    Yes, I had this problem. Service call required to replace the glovebox. Maybe just the solenoid catches on the sides.
    RT
  3. SDM3
    SDM3 Member
    SD
    Thanks.
  4. CWFLY
    CWFLY Member
    San Diego
    #4 CWFLY, Jun 17, 2018
    Yesterday, mine started doing the same.
    Close for a second or two, then came open. Somewhat random.
    On the left side, you'll see an electric latch. Pull lightly on it... Mine went from 1cm to 2cm protruding when I pulled lightly on it, suggesting to me that it was sticking. I think the switch/solenoid needs to be replaced.
    So.........
    Who do I call. I hate to have roadside service come to my house ... not urgent. But I would like to get it fixed in a day or two. Service centers don't seem to be open on the weekends.
  5. Nikola M3
    Nikola M3 Member
    so cal
    Mine is doing the same, will have service look at it. If i pull on the latch it comes out a bit further than when it returns on it's own.
    My temporary fix is to close the door and push on the left side (where the latch is) for 5-10 seconds. This allows the latch to move a bit further holding the door shut.
  6. MosquitoFloss
    MosquitoFloss Member
    Los Angeles
    Did you guys ever have it fixed? Mine just started displaying the same behavior.
  7. Nikola M3
    Nikola M3 Member
    so cal
    mine is going in for service on Thursday, this is one of the things to be addressed. I'll post back once it is solved.
  8. MosquitoFloss
    Los Angeles
    Mine had stopped phantom opening for quite some time. Then today I had to open it and it will no longer stay closed. Can't get it in for an appointment for a couple of weeks. Guess I'll be driving around in my new car with a duct-taped dash. Sweet.
  9. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I had this issue and I called service and a Ranger came by to fix it. It took him maybe an hour to replace the latch assembly and to liberate it.
  10. teddyOphilly
    teddyOphilly Member
    NJ
    Have the same issue. Scheduled a mobile appointment. Is it under warranty and the service complimentary? My M3is about a year old.
