This sounds like a pretty good plan. If I were running this program, I'd add apartments to the list of priority locations, on a par with workplaces. IMHO, we need good Level 2 charging infrastructure in place at workplaces and apartments, to make EVs practical for people who don't own their homes. GM's priorities are better than putting them in at supermarkets or restaurants, though, where a lot of Level 2 EVSEs are still being installed. (DC fast chargers at those locations, OTOH, would work well.)"We want to put a focus on workplaces," Hassani told me. "Workplaces covers the gamut of companies we all buy products from to schools, hospitals and health care facilities and so forth. So workplaces is a very important category that we want to prioritize and then other areas that we're also prioritizing are recreational destinations, parks, sports and entertainment venues and so forth, places with high dwell times."
IF they charge at 350. My Taycan charges insanely fast + can regen up to 265kw.Will be interesting when we have GM vehicles that can charge at 350 kW 800 volts at electrify america network. Tesla currently only goes up to 250 kW.
With LG chem supplying they will all be Level 2 limited by designMeh. Level 2 ....
Exactly. So much talk about 350kW charging and nobody gets it.
Well, there was an article about the Ultium in Car and Driver a while back that stated that the Hummer pack will be able to switch from Series to Parallel to allow 800V/350kW charging but driving will be 400V. They are also using wireless monitoring which is supposed to dramatically lower the amount of wiring in the pack.IF they charge at 350. My Taycan charges insanely fast + can regen up to 265kw.
Huh??They are also using wireless monitoring which is supposed to dramatically lower the amount of wiring in the pack.
Here is the article:Huh??
Wireless is asking for trouble.
Interesting. Perhaps a custom protocol with a simple data structure for brevity, and if enclosed in pack will be isolated from external noise.Here is the article:
How GM's Ultium Battery Will Help It Commit to an Electric Future
An inside look at the new battery powering General Motors' electric future.www.caranddriver.com
And the relevant paragraph:
"Typically, automakers need a throng of wires to monitor the hundreds of individual cells in a pack. But GM found a way to monitor the Ultium's wirelessly. Each group of two or three cells wired in parallel broadcasts key information such as temperature and voltage several times per second. This reduces the pack's wiring by 80 percent compared with the Bolt's—eliminating a source of warranty claims, improving packaging, and simplifying the wiring harness. Plus, GM claims this setup consumes no more power than a wired system."
...and yet, Tesla does it with a simple two wire opto-isolated serial bus daisy chained between modules and the central BMS. There is no good reason to run 96S to 220S wires through the whole pack to the BMS.Here is the article:
Level 2 is road trip worthy
Agree....and yet, Tesla does it with a simple two wire opto-isolated serial bus daisy chained between modules and the central BMS. There is no good reason to run 96S to 220S wires through the whole pack to the BMS.
GM dealerships did have Level 2 EVSEs many years ago. Here's the PlugShare entry for a GMC/Buick dealership near me, showing the first checkin occurred in 2013. There's a Chevy dealership across the street that also had a Level 2 EVSE installed at about the same time; however, PlugShare has truncated its checkin history, probably because that dealership upgraded and moved its EVSE to a different location on the property. I leased a Chevy Volt from this dealership in 2016, and I or the dealership charged that car there from time to time -- mostly after routine maintenance visits.Level 2 chargers at dealerships should have happened ten years ago. Nice job, GM.
