The Gemini wheels are 19x9.5 with +45 offset. Does anybody know if replacing the Gemini with 19x9.5 wheels with +35 offset would make the tires rub on the fenders. The +35 offset means the tire will stick out (away from the car) by 10mm.
Thx
you're fine. There's plenty of suspension travel. Plus, as you moving, it'll create slightly more negative camber. You'd only have to worry about rubbing if you slam it ~ 3 or more inches, but even then it'll probably have more negative camber.
