GPS Antenna Disconnected/Backup Cam black
Discussion in 'Model 3' started by Salted, Mar 6, 2020.
  1. Salted
    Salted Member
    Tonight I walked from the grocery store to our M3 LRDMP- and was greeted with this message:
    "GPS Antenna Disconnected"
    "Navigation and Autopilot limited"
    Also, the backup cam image is black, though the guide lines do show up. (Felt quite awkward backing up at night, in the rain, without the nice big screen!) I haven't found other reports like this. The fact both went out at the same time hints at a connectivity problem. Do these use a chassis ground? I think both the antenna and the camera are on the trunk lid, so I might explore further, but thought I'd post here for ideas before tearing up carpet.
    Thanks!
  2. Wennfred
    Wennfred Supporting Member
    San Diego
    Did you try the 2 button reset?
    Fred
  3. Salted
    Salted Member
    Yes, sorry. Should have mentioned that. Two button, then brake version without effect.
  4. Wennfred
    San Diego
    Submit a service ticket using your App, seems the car is new. Hopefully a Moblie service ranger can help if you are far from the nearest service center. That is a weird one as I haven’t read about that one either.
    Fred
  5. Wennfred
    San Diego
  6. Salted
    Salted Member
    Thanks. That was the only similar one I'd found, but they're model S and no backup cam problems.
    I have a service appointment scheduled but am still hoping something simple turns up. The way both problems hit all at once though vs. developing or being intermittent likely means I'm reaching.
  7. Salted
    Salted Member
    Ouch. The wiring loom going from the trunk lid to the body looks suspicious. (Passenger side, standing by the rear wheel) The pic doesn't do the collapsed area justice; it's harsh.
    I wouldn't be upset if anyone else happened to compare with their own... If you do, please note if the conduit maintains a curve or if it kinks anywhere through the trunk lid's range of movement. Mine only bends (~90%) at the kink, which has to stress any wires inside. Since both the camera and GPS are angry, could they share a ground? The other trunk lid electronics do work (lights, trunk release, license lighting).
  8. Salted
    Salted Member
    Rats. Just learned the GPS antenna is in front, on the windshield, behind the front-facing camera. So much for trunk wiring being the cause. :/
  9. Salted
    Salted Member
    Yesterday I received a text from Tesla saying they need me to reschedule my service appointment because they're waiting for parts. Soon after that the backup camera and GPS started working again! No word yet if they kicked it back to life remotely but it does sound like diagnostics identified a problem.
  10. Wennfred
    San Diego
    Cool, good to know.
    Thanks
  11. acdleon
    acdleon Member
    Corona
    Did you find out if they fixed remotely and the cause?
  12. Salted
    Salted Member
    No I did not. That was March. (Wow) Because of all the uncertainty back then, and Oregon's only SC being almost centered in Oregon's first hot zone, I cancelled that appointment. Fortunately the camera and nav have been fine since.
  13. GoodManFrank
    GoodManFrank Member
    Bay Area, California
    I'm having the exact same problem today. Shows
    Also backup camera views are blank. Driving visualization disappeared (seems like just all cameras are offline)
    Scheduled a service appointment and will see how it goes.
  14. GoodManFrank
    GoodManFrank Member
    Well just got the car back. I didn't get any luck before service visit, but they fixed the problem by simply doing a 12V battery reset.
    I believe it's something like this The definitive guide to RESET on Tesla Model 3
    Quote:
  15. abdoayoub
    abdoayoub New Member
    Wednesday
    Toronto
    Just went through this on my M3 SR+. With the first ticket, when the technician came out, the car was mid update and thought that it would be resolved with the update. that didn't work.
    on the second ticket, the technician suggested i move the toll pass (Easy Pass) because it was on the same side of the mirror where the GPS module is and that fixed it for me.
