GPS off by 65 miles
Discussion in 'Model S' started by Sandy Chamois, Jan 14, 2017.
  1. Sandy Chamois
    Sandy Chamois Member
    Northern New Jersey
    yesterday, my 2016 Model S 60D GPS began showing the car moving in the opposite direction as I was commuting home form Manhattan to NJ. Is shows the car now in Oyster Bay, Long Island. The app shows the same. This messes up my air suspension auto raising, homelink and the speed limit signs are no longer displayed. I reset the touchscreen twice, to no avail. My Model X GPS is fine. Any ideas how to fix?
  2. artsci
    artsci Sponsor
    Timonium, Maryland
    There are several other threads on this problem. I've experienced it myself. -- it had me in the middle of the Atlantic Ocean not far from where the Titianic sank:) The fix required replacement of the rear window (the antenna is embedded there).
  3. purduelion
    purduelion Member
    Illinois
    I had the same problem and it was solved with the first at home OTA software update. I did NOT need anything replaced...
    You can also try resetting both displays. First the main, and right when that goes black reset the mini display.
  4. artsci
    artsci Sponsor
    Timonium, Maryland
    Worth a try but I doubt that it will be permanent fix. When I had my problem I did that at least a dozen times. Now and then it would get the GPS correct but then the system would default to errors. I lived with this for about a month before taking it to my SC for the fix.
  5. Spyder14
    Spyder14 Member
    Bluffton, SC
    I know you have made a lot of great mods but now amphibious??!!! o_O
  6. ThisIsTrue
    ThisIsTrue Re-member
    'Western Slope' Colorado
    No surprise: he just wanted the James Bond mode to be real!
