Please help update which parts received the graphite interior finish, their part numbers and pricing as well as methods and related third party parts and services. Updated in Graphite Spring 2018: 18 parts $80.00 USD MCU BEZEL ASY LHD GRAPHITE (graphite is 108394401-B, silver is 100229400-B) $108.00 USD Instrument Cluster Bezel (graphite is 1033041-01-C, silver is 600772500-B) left of instrument cluster vent right of instrument cluster vent passenger dash left vent passenger dash right vent dashboard trim (attached to dashboard, part number varies by finish) left front door panel trim (attached to door interior, part number varies by finish) right front door panel trim (attached to door interior, part number varies by finish) left b pillar panel trim (attached to b pillar interior, part number varies by finish) right b pillar panel trim (attached to b pillar interior, part number varies by finish) left rear door panel trim (attached to door interior, part number varies by finish) right rear door panel trim (attached to door interior, part number varies by finish) console sliding drawer handle console front cup holder accents console rear cup holder accents (assumed graphite, needs verification) console rear vent assembly (assumed graphite, needs verification) Steering wheel accent Not currently upgraded in Graphite: 13 parts left front door handle right front door handle left rear door handle right rear door handle Performance Pedals (2 total) upper left column handle (turn signal) accents and button lower left column handle (cruise and autopilot) accents and button right column handle and button (drive select) front window and mirror button cluster accents, three other door window button accents (4 total) Closest 3rd party wrap materials: 3M: 1080 M261 Matte Dark Gray Avery: Matte Metallic Charcoal SW900-845-M VViViD: VViViD+ Premium Charcoal Grey Satin Semi-Gloss Oraful ? Arlon ? JMR ? Ritrama ? KPMF ? Mactac ? Since leather was discontinued before graphite trim was introduced, those part numbers will never be upgraded to graphite obviously.
If you only replace one piece in graphite, replace the CID/MCU bezel. Everything else in this picture is silver:
Yes, to taking the dash apart which is not for the faint hearted. Here is Jason Hughes doing it (at 50 sec mark):
It turns out that the dash trim is separate from the vents. If I had known that I might have replaced the vents at the same time as the bezel.
I went through the parts list today and put together everything that would be needed except for the steering wheel trim. I can't find that anywhere in the parts list. I only see three steering wheel options standard, heated, and PUR VEGAN. I am not sure if anything in this group as a source to find pricing on these but this would be a cool kit for the service center to offer customers who want to change up their interior a bit. My only disappointing bit is I have an Alcantera dashboard and to get the graphite trim I would have to switch to the Vegan dashboard and loose the Alcantera which I think looks nice. Graphite Interior Conversion TOP PAD 12A PUR/PUR BLK GRAPHITE MS LHD 1060695-12-G ASY CLUSTER BEZEL GRAPHITE 1033041-01-C MCU BEZEL ASY LHD GRAPHITE 1083944-01-B IP AIRVENT RING GRAPHITE/BLK LEFT LHD 1061731-02-B IP AIRVENT RING GRAPH/BLK CTR LEFT LHD 1061732-02-B IP AIRVENT RING GRAPH/BLK CTR RIGHT LHD 1061733-02-B IP AIRVENT RING GRAPHITE/BLK RIGHT LHD 1061734-02-B ASY GRAPHITE DECOR PULL CUP LH FR (SERVICE) 1051387-02-A ASY GRAPHITE DECOR PULL CUP RH FR (SERVICE) 1051388-02-A ASY GRAPHITE DECOR PULL CUP LH RR (SERVICE) 1051389-02-A ASY GRAPHITE DECOR PULL CUP RH RR (SERVICE) 1051390-02-A The Center Console door will change depending on your interior trim: SLIDING LID, LINEAR DARK ASH GRAPH 1058088-22-A SLIDING LID, FIG ASH BURL GRAPH 1058088-19-A SLIDING LID, OAK GRAPH 1058088-23-A SLIDING LID, CARBON GRAPH 1058088-21-A
Missed two more part on the list. The cupholder in the center is graphite as well. TRIM DECOR, PUR, LINEAR ASH BURL BLACK GRAPH 1065900-22-C CENTER CONSOLE ARMREST DECOR - FIGURED ASH BURL - GRAPHITE 1047750-19-C TRIM DECOR OAK GRAPHITE MATA 1024237-23-C TRIM DECOR, CONSOLE, D-CARBON FIBER MATA GRAPH 1024237-21-C TRIM DECOR FIGURED ASH BURL GRAPH 1065900-19-C ASY VENT BEZL CUP HOLDR GRAPHITE 1064501-01-B I also forgot the second row cup holder is Graphite as well. ASY SECOND ROW CUP HOLDER GRAPH 1086670-01-C The rear vent didn't get the Graphite Treatment.
Anyone look into a paint or vinyl wrap (e.g. chrome delete style) solution to achieve a similar look?
I haven't yet but I am curious how this new design will wear. The current Satin chrome finish scratches and dents very easily. I have a couple dents in mine already so I am good with swapping for the newer part but I am interested in the wrap in one spot. The dashboard trim at the top is attached to the dash top and my current dash is alcantera but there is no alcantera with graphite so a wrap for that part would be nice.
A friend found the part number for the graphite steering wheel. It is pricy since that is the airbag assembly. NAR, DAB ASSY, LEATHER - HEATED GRAPH 1456163-31-A pricing on that one part is around $680. My thought is to change everything else except the steering wheel and some day when and if the airbag needs to be swapped then do it at that time.
I thought I might just black matte wrap the aluminum on the steering wheel, including the logo in the center.
So I upgraded the bezel trim piece and all the air vents for my MCU replacement to MCU2. Here are a few photos. I think I might be the only graphite trim with alacantara dash. Still have a few pieces to do and maybe some vinyl wrapping.
This is beautiful. Trying to find the graphite MCU trim itself as that is what ends up blinding me the most during drives.
I purchased some "VViViD+ Premium Charcoal Grey Satin Semi-Gloss" and will be wrapping mine within the next month or so. I'll post some pictures when it's done.
Love it! I am currently in the process of 'chrome deleting' my interior. I got real carbon fiber pieces for the door trim (looks insanely good!). They can be bought from RPM Tesla. Getting the main dash pieces this week as I didn't like the matte carbon fiber from Tesla, as well as carbon fiber covers for the window switches and the steering wheel trim. The question now is how much will the graphite pieces be? Does anyone mind sharing what they paid? 4 vent pieces Instrument cluster bezel Infortainment MCU bezel Also, is the graphite bezel compatible with the earlier models? I know they changed the thickness at the bottom.
I got the bezel of the MCU and instrument cluster replaced with graphite and it looks great with the carbon fiber trim. I had requested that the MCU bezel get replaced and the ranger came with the bezel for the IC and I agreed to have that done, too. I'm glad I got them both done. They blend in well instead of attracting extra attention.
Would you be able to share any pictures? Also, are you planning to replace the rest of the trim in the interior (on door panels, dash cover, B-pillar)? Interested in doing something similar but not sure how much replacing everything would cost. Thanks!
