Great Ski Rack (minor DIY required) for Model X
Discussion in 'Model X: Interior & Exterior' started by NovemberXray, Dec 27, 2016.
  1. NovemberXray
    NovemberXray Member
    Portland, OR
    I have come up with a ski rack alternative for my Model X that I am very happy with, so I thought I would share.
    I had a bunch of roof rack mounted gear for my previous car, including a ski rack, and I already have a hitch mounted, tray style bike rack, so I really didn't want to spend $400 on another hitch bike rack that I wouldn't use, PLUS a ski rack attachment thing, all of which results in a very tall, wobbly, mess on the back of the car, and potential supercharger issues.
    So I got a SportRack cargo basket for the hitch, and I was able to easily attach a regular ski rack to it, allowing me to carry 4 snowboards, or skis (might not work if you have really long skis) in a horizontal position behind the car. It's compact, way cheaper, useful for other things as well, and it folds up so you still back into a super charger!
    I used a Thule ski rack, and it's attachment straps are mounted to the ski rack with a single bolt, the only thing I had to do was take one off, drill a hole in the aluminum, and move it close in by a few inches so it would fit the SportRack basket. The ski rack will also still work fine on a roof mount if you want.
    Here's some pictures:
    • Informative x 7
    • Like x 5
  2. vandacca
    vandacca ReActive Member
    Hamilton
    I only wish there was a better way to protect the boards from road grime and salt.
  3. NovemberXray
    NovemberXray Member
    Portland, OR
    True, but it's almost as bad on the roof. I have a full snowboard bag that would protect the gear, but then the bag would be filthy. Pretty easy to hose off the boards...
  4. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Those are snowboards, not skis. Skis are longer.
    Also what does it do to the rear sonar sensors? Don't know about your state, but here it would get you a ticket for hiding / obstructing the license plate if travelling in the folded position. I also would put those boards into a bag to keep out the grime and snow.
  5. NovemberXray
    NovemberXray Member
    Portland, OR
    The car is 226cm wide, so you can fit almost any ski without it extending beyond the mirrors.
    I don't drive with it in the upright position unless it's empty, which then does not obscure the license plate. This solution covers far less of the back then the hitch ski solutions sold by Tesla, Yakima, and Thule.
  6. goneskiian
    goneskiian Active Member
    Bellevue WA
    Yeah, I used to have some 220+ cm skis but don't race DH any longer so I'm not too worried about that! :rolleyes::p;)
    Thanks for sharing @NovemberXray! I have some Yakima FatCat 6's sitting around that I almost sold. I wonder if I can get those to work. Anyway, we finally took the X up for some skiing and our 2 pair fit inside just fine (6 seater).
  7. Ambidexter
    Ambidexter Member
    Los Gatos, CA
    Thanks for the idea! It's an ingenious solution. What's the vertical height off of the road if the bottom of that rack as compared to the body of the car?
  8. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    Thank You.
  9. NovemberXray
    NovemberXray Member
    Portland, OR
    @Ambidexter I haven't measured it, but the basket angles up slightly in the horizontal position, so the whole thing is a couple inches higher than the trailer hitch, which is also higher than the lowest point on the car...
  10. felixtb
    felixtb RsEU502,Sp+14274,XpEUSig4
    Lausanne, CH
    IMG_0305.JPG IMG_0308.JPG IMG_0353.JPG IMG_0354.JPG I have another roof rack solution that works really well and is maybe more traditional......
    Here are a few photos of my roof box config and my ski rack config with the same base support.
    I took sea sucker kayak bars and shortened the back one by 11cm. Also switched out as a later upgrade the inner suctioncup on that bar to a smaller one to fit better on the central roof strip.
    I use an off the rack ski holder solution that I swap out for a Thule Touring Sport roof box.
    When using the ski holder the free FWD works as normal. However, when using the roof box one has to override the censor from the touch screen to open properly. Minor inconvenience considering the benifirs.
    • Informative x 4
  11. PeterK
    PeterK Model X Owner
    Cambridge, MA
    Both (all three?) of these are very smart solutions, thank you both for sharing them.
    How much do they impact range?
  12. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    I have similar trailer hitch carrier for my Tahoe that I load with stuff when we're packed full in the car to take to my cabin. I put whatever I carry on it in heavy duty garbage bags, then I tape them up with packing tape and strap it to the carrier. I did this with luggage recently when we had visitors. When I get to my cabin, I cut off the garbage bags and throw them out and everything inside is clean.
    There's no hosing off things when it's below freezing outside unless you take things inside and into the bathtub but the last thing I want through my drainage pipes and in my septic tank is road grime. I find it much easier just to put things like those snowboards in garbage bags.
  13. McManX
    McManX Member
    Silicon Valley, CA
    I made a similar one to your second one last month (sorry forgot to post pics).
    Also for anyone who is interested, seasucker now has their pre made ski rack available (finally and at a price).
    Ski Rack
  14. awillys
    awillys Member
    London
    Hi,
    I have done a bit of research as well and the best thing I found for me is the MFT Backbox: BackBox_en | mft transport systems
    Video at
    it supports ski up to 187cm long.
    It's tall enough for few more gears. So that's where I am going I think.
  15. NovemberXray
    NovemberXray Member
    Portland, OR
    That looks great! Definitely a more expensive option, but very nice. Looks like they do ship to the USA.
  16. vandacca
    Hamilton
    It looks like you need to also get the BackCarrier (Art. No. 1201) hitch mount. Also, it only comes with the small insert and if you wanted the medium or large insert to expand the area, that's also extra.
    Does anyone know with certainty that this system is compatible with US/Canadian vehicles? Are the trailer light connection the same? Is the BackCarrier configured for a 2" hitch?
  17. MX458Dave
    MX458Dave Member
    Boulder
    Here is my ski rack system. Love the others above. I used my old yakima bike rack, my thule long ski racks from my old roof rack, and a $35 hitch extender, so that I can open the back at all times. It folds down for parking or supercharging, and when up I can see out the back and with the camera. It locks the equipment and to to car. Currently holding 4 skis and 2 snowboards. Lots of room in the X, so don't miss my roof box for the rest of the equipment.
  18. MX458Dave
    MX458Dave Member
    Boulder
    Could you use the seasuckers sideways on the back glass? That would allow the falcon wing doors to still work...
  19. awillys
    awillys Member
    London
    Hi,
    I personally don't know however I could ask the supplier.
    I think I will definitely be getting one, for winter ski/snowboard but also summer wakeboard/kite surf.
    so just before I call them, if anyone has more question drop them here i'll ask everything in one go.
    best
    A
  20. larmor
    larmor Active Member
    Irvine, CA
    Very good solutions. Also interested to know how it affects range.
