I believe the charger is waterproof. Is there a way to turn the light off?
Turn off it’s circuit breakerIs it normal for the green light to always be on a steady green when not in use? I don't necessarily want to advertise that I have a Tesla charger on the side of my house. There must be a way to turn the indicator light off?
... not good idea to cover up any electrical device ... it needs natural convection ventilation otherwise the high temp sensor will kick in unexpectedly.Cover it with a rain proof bag of some sorts?
It not recommended by NEC ... but I saw an install from Australia on YouTube and they had what they called an "isolation swtich" which obviously is allowed there. I have seen motor starter/disconnect switches installs for industrial applications, but these devices are expensive. I don't know if a "pull out" disconnect device typically used for A/C will be suitable.That was going to be my suggestion, but if that's a PitA to get to, then install an a/c isolation box next to the HPWC and turn it off there
Just make sure you get one appropriate for the amperage
Is that still the current EVSE? Because I'm with @steph746 - I have two chargers on my porch now andHere's a thread I made quite some time ago with some disassembly pictures: Gen3 HPWC disassembly, with overheating issues explained!
Yes, that's the current version of the HPWC.Is that still the current EVSE? Because I'm with @steph746 - I have two chargers on my porch now and
- Looks really conspicuous...this neighborhood is quiet but don't want to extra-attract eco-vandals or just thieves
- The bright green interferes with say Christmas or Halloween or Valentine's porch light colors.
I'm thinking the only "fix" is to put some maybe masking tape to reduce the light output drastically, but still be able to see the light if that makes sense.
