Damn did you hear that from Curt or from Dcbel?
I think you could grid-defect if your Powerwall system could think it's "grid charging"... but it ends up really just pulling power from an EV battery. Even if you only got 10 kW, I think it'd be enough to keep you going in the Winter without having to deal with PG&E's BS since you could just get your energy somewhere else and drive it home.
But on the plus side, since you're NEM 2.0 you have a decade or so before you lose grandfathering and need to consider this.
I will respond to each relevant question/comment you raised below.
Self Installation:
While dcbel is designed to be simple to operate, installing the unit requires a licensed electrician. That’s why we partner with Smart Home Integration Partners (SHIPs) who are local experts in smart home energy for the installation. You will, however, work closely with the SHIP and have full visibility over the installation.
Tesla Powerwall:
dcbel does not currently support integration with the Tesla Powerwall. dcbel performs the DC to AC conversion using our patented PUC5 multi-level converter technology and thus, requires a DC input.
Tesla Compatibility:
dcbel r16 can currently fast-charge and solar-charge a Tesla through the use of an adapter. However, Tesla vehicles are not compatible with two-way power flow. Employing bidirectional charging would void Tesla’s warranty and cause technical issues with the vehicle.
Nissan Leaf:
You can charge and solar charge
Nissan Leaf with dcbel r16. In terms of blackout power, currently, only EVs built to the CHAdeMO standard are compatible and with the most popular model being the
Nissan Leaf (2013 model or later). It is a perfect match!
Connector Combination:
You can outfit a dcbel r16 with one of two connector combinations: AC J1772 and CHAdeMO, or AC J1772 and CCS. In other words, one AC connector and one DC connector are required. Bear in mind, however, that CCS vehicles can still be charged via a Level 2 AC J1772 connector.
Breaker:
dcbel r16 should be connected to a 120-volt main breaker panel and a breaker panel with enough room for the required breakers (ideally 200A or more). For more technical details and wiring diagrams, we encourage you to read our
spec sheet and a more detailed user manual will be published soon. Stay tuned!
Wiring Diagram:
Availability:
We are currently taking reservations for installations for Q2-2023. We encourage you to reserve your unit
here.
Finally, I do see you have requested a callback. Please select an appointment
here.
Best regards,
The dcbel Team
