Ground clearance of X compared to S
Discussion in 'Model X' started by Larry, Oct 12, 2014.
Tags:
  1. Larry
    Larry Member
    East Bay of SF
    Will it be that much higher for ease of getting in/out? Anyone have an idea? Trying to decide to upgrade to a D or wait for the X. Thanks for any info.
  2. jerry33
    Texas
    I can't see the X being any higher than the S because it's the same platform, only the body style is different to accommodate the third row. It's possible they will use slightly different tire sizes, but that won't raise it up by more than 10mm or so, using any tire size i can imagine being used.
    In both, you can use an "exit" setting to raise the vehicle up for ease of exit.
  3. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR;YLR
    Colorado
    You won't climb up into the X, but the roofline will be significantly higher so the door opening should be enough taller to make entering the car considerably easier. At least, that's my current working theory.
    :biggrin:
  4. sigurdi
    sigurdi Member
    Norway
    It will also be more space between battery and seats, meaning seats will be rised compared to Model S, entering will be more sliding in/out.
    Not sitting down getting out. :)
  5. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    The Model X test mule, the one with the ballast on the roof to simulate a higher center of gravity, was jacked up a little bit too. Going off that, I'd say the Model X will have an inch or two more clearance than the Model S.
  6. Larry
    Larry Member
    East Bay of SF
    I'm just going to have to be patient and wait for one to become available to actually sit in it. Tough to do though.
  7. NigelM
    NigelM Recovering Member
    Northern Virginia
  8. eco5280
    eco5280 Member
    Country
    I would be surprised if the X didn't offer (standard or optional) the air suspension that allows even greater ground clearance. It's on lots of high-end SUVs and the S so it's a no brainer that they'll put it on the X. (Just too expensive IMHO)
  9. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    The Model S sits really low. Almost 2" lower (when set to suspension low) than the Focus Electric I have. I expect the Model X to sit 2-3" higher. And offer higher speeds at elevated air suspension heights.
  10. Larry
    Larry Member
    East Bay of SF
    Nigel
    i looked at that pic and just couldn't tell if photoshopped or the vehicles were actually sitting next to each other.
  11. mikevbf
    mikevbf Supporting Member
    vermont
    I really do hope they significantly increase the clearance without too much of a hit on cornering. It is one of the things I have most looked forward to in the Model X. I want the Model X to be as or more capable of navigating things like deeply rutted roads and deep snow as other CUV/SUV's while blowing them away in the corning department due to the lower cog. I realize it will not be able to out corner a Model S if they increase the clearance, but it still makes sense because that is what CUV/SUV's are about: higher seating with more clearance and usually some form of AWD.
  12. Red Sage
    Red Sage The Cybernetic Samurai
    Los Angeles CA
    I hope the Tesla Model X offers a wide range of adjustable heights with an air suspension. I seem to remember there was a version of the Subaru Outback that had around 8" of travel in its height adjustment. That would do the trick nicely.
  13. mikevbf
    vermont
    If the air suspension is packaged like it is with the Model S, then you will need to pony up an extra 6.5k which is fine if you want all the other tech options and auto pilot, but not if you just want a little more clearance. I still hope the Model X comes with extra clearance even without the air suspension.
  14. Hank42
    Hank42 Member
    United States - NY
    I wonder how the higher ride height might affect center of gravity - that batter pack is REALLY heavy and raising it higher can have a significant impact on handling.
  15. Svenssons
    Svenssons Member
    q
    The center of gravity would only rise 10 cm at most at highest setting and would still be lower than most if not all SUV:s. You are not going to drive at higher speed with highest setting either. The car will automatically lower itself in higher speed.
  16. mikevbf
    vermont
    I believe they have been testing this impact since at least the beginning of the year by modifying a Model S. Check out the Model S Test Mule thread to see what I mean. Look at the 3rd photo down in the first post for increased clearance and post #9 for Mikes comments.
    http://www.teslamotorsclub.com/showthread.php/27765-Model-S-Test-Mule
