when I got it with 44,000 km it still had the original cabin filter; if it had been to service they would have changed that...
How do you know it was the original filter?
And I think Tesla only changes the filter as part of a paid annual maintenance visit not as part of a warranty service visit. So it could have had any number of warranty visits...
You're right, good point, it could have been brought in for just this reason, or other warranty issues and not serviced. It would be nice if someone could tell me (us).
The cabin filter definitely had 44k of dirt in it; assumption still yes, it could have been changed at 10k and the car driven in very dusty areas for another 34k, but there is no other evidence that the car has been in severely dusty areas. i.e.: rock chips from gravel roads. I have seen my share of cabin filters over the years and most I have seen have half the crud at 60,000 km. So while I have no way of knowing for sure, me thinks it has been there the whole time.
Hi2 weeks ago my right headlight started failing. So I ordered 2 HID D3S bulbs on Amazon and scheduled to tackle that job this weekend. The last Wednesday I get "Coolant low" message. Made appontment with Tesla service but was assured not to worry - probably a bad ground. The I got intermittent 3 beeps with a message flashing on the IP and main screen but not long enough to read. Also "Suspension needs service popped up frequently. I got worse yesterday while driving in the morning. In summary the following happened intermittently:
- message: Coolant low ( just when starting car )
- right headlight not working
- right turn signal intermittent ( for about 20 minutes, then working)
- message: Suspension needs service ( on permanently until full power off, then re-appearing)
- message: front trunk lid open (this was the 3 beeps and message happening frequently)
- phone notification: Car alarm has been triggered
I thought that there must be some commonality to this, like a bad ground. I removed the Frunk tub and Voila! a broken ground lug / stud merrily swinging in the air. Looks like too much torque was applied at the factory.
Drilled into the broken stud and tapped a thread
Then sandpapered the stud and brass lug connected to the 2 wires. Temporarily connected a jumper cable to the brass lug and low and behold the headlight worked and all warning messages disappeared.
Went to Hindle's Hardware in Clarksburg Ontario ( that is in the area where I was visiting ) and got a brass bolt with 2 nuts and special electrical paste for joining dissimilar metals. Reason for brass bolt is that the lug on the 2 wires was already brass.
That Hardware store is amazing! Right out of the 30's complete with crank cash register. If he doesn't have it then it doesn't exist.
Here is the finished job. All problems were solved by this including the malfunctioning headlight.
Total cost of repair CAD$ 5.20 ( and 2 beers and my time )
Thank you for your help. Will it be better when I use screw from Aluminium? I I understand cable and ground (part on the car) is from Aluminium. So when I use Aluminium screw will it be fine?
