What he means by this is normal silicone caulk cures by offgassing acetic acid. (the vinegar-smell of caulk) This can corrode electrical connections. For this you'd use RTV silicone ('Room-Temperature Vulcanizing') which has a more neutral catalyst, although trying to caulk something like this is counterproductive as water will usually find a way in (from the back? Condendate?), and caulk will actually retain it.Brush clear grease over the joint, sealant that is not acid curing (non silicone) is ok too.
Cad is toxic if you weld it, which is bad for the weld too. Aircraft bolts will net be toxic if you use normal precautions in handling
Someone asked, what do aircraft do? Quite simple, aircraft bolts in aluminum are plated with Cadmium, which is corrosion inhibiting and a good galvanic match with aluminum. Ground connections in aircraft have the paint removed under where the bolt head contacts the structure, check for resistance less than 1 ohm, then over coat with polysulfide sealant.
... If any of you who have had this problem or who live in the northeast have not done the power steering recall yet, do it immediately. I had the exact same corrosion on all three of my power steering bolts and it made for a huge repair of the entire steering column instead of just a bolt replacement (thankfully, Tesla comped it because it was related to the recall).
Didn't VW just have to perform a recall on their cars because the charger contained a very small amount of cadmium? (Yep they did.)
I don't think you are allowed to use cadmium in a car...[/QUOTE
Not sure what form the Cad was in the charger, but doubt it was plated hardware..bolts I mentioned are
common in ALL aircraft, anyone can buy this hardware.
In this case, I like what Robbie did. Stainless all around.
2 weeks ago my right headlight started failing. So I ordered 2 HID D3S bulbs on Amazon and scheduled to tackle that job this weekend. The last Wednesday I get "Coolant low" message. Made appontment with Tesla service but was assured not to worry - probably a bad ground. The I got intermittent 3 beeps with a message flashing on the IP and main screen but not long enough to read. Also "Suspension needs service popped up frequently. I got worse yesterday while driving in the morning. In summary the following happened intermittently:
- message: Coolant low ( just when starting car )
- right headlight not working
- right turn signal intermittent ( for about 20 minutes, then working)
- message: Suspension needs service ( on permanently until full power off, then re-appearing)
- message: front trunk lid open (this was the 3 beeps and message happening frequently)
- phone notification: Car alarm has been triggered
