Garlan Garner
Banned
I just got my kit on Wednesday. I will install on Sunday. There is a 12V power source right underneath the rear seat on the passenger side so there is no need to run the power wire to the front of the car.
Instruction here -> There are 2 latches under the fronts of the cushions, one each side, about in the middle of each seat, move the latch from left to right (facing the rear) and the cushion locks will release. Then just pull it up and out, watch for seatbelt locks and heated seat harness, one left and one right, but there's enough room to unhook both.
Take the cushion out, on the passenger rear side, there's a foam block to support the cushion, just pick it up, not secured, underneath you'll see a battery dataport, and a red rubber boot.
The red rubber boot contains the 5/16"x18 bolt with a wire attached.
Another option is to run thru the right front fender and connect directly to the battery without punching through the firewall.
I wouldn't call it "punching through the firewall".
Its a rubber grommet that is super simple to run a wire through.
Is the connection under the seat "always on" like the battery is?
