I'm planning on buying 2012-2016 gtr 10 spoke wheels for my model y long range. I'm pretty sure they fit but not sure about the rear offset and center bore. These are the specs for them.
Center Bore: 66.1 mm
– PCD: 5x114.3 (5x4.5)
– Wheel Fasteners: Lug nuts
– Wheel Tightening Torque: 132 Nm
– Thread Size: M12 x 1.25
255/40ZR20 97Y 285/35ZR20 100Y
9.5Jx20 ET45 10.5Jx20 ET25
Your fronts are going to look "tucked-in" with such a high offset. Adding a 12mm spacer there would take care of that though. As for the rear, that's about the max offset you want. It may even have a slight "poke". As for the center bore, you are going to need a set of hub rings to go from 66.1 down to 64.1.
Very
Very similar issue on some wheels I'm looking at adapting for my MY. Specifically I've a set of 18x7.5 with a 42 inset and a center bore of 72.6. The bolt pattern matches. Thoughts?
Very
I suppose my only real question relates to the difference between the 72.6 center bore and the Tesla center bore spec of 64.1 - is it possible to adapt that 8.5mm difference in bore size?
For the much a large difference in bore size, I'd recommend getting spacers with the difference milled onto them already. So for example, if you get a 15mm spacer with wheel studs (+matching bolt pattern) and the center bore of 64.1mm, you kill 2 birds with one stone. H&R makes very goos ones.
Did you ever get this done? Send some pics bruh
