I know. It's electric and don't need inspection and some people are at 100k miles and the car is fine. I bought the 8 year annual inspection when I bought the car and each year i'm thinking about just getting it refund. So Tuesday I drop my car for my 2 year inspection.
End of the day got a call that they found some problem with the suspension and the battery louver.
"Rear toe links loose, leaking LH rear shock, both rear bearings are loose as well at RH
front bearing."
and
"RH condenser louver assembly inoperative found during inspection. Replaced louver
assembly."
At final.. 3 bearing assembly, 1 rear coil spring module and 1 active louver assembly got replaced. I know each bearing is around 800$ canadian. No clue for the coilspring module and the active louver.
I'm at 57k kilometers. God i'm happy that they found that before my warranty end, and now i'm thinking about buying the extended warranty -_-
front bearing."
and
assembly."
