Twice my GW2 has stopped using the Ethernet interface, claiming that it is "configured but not connected; check cable". The first time was a day after installation about a month ago and the second was yesterday evening. Both times I could see the Ethernet link lights blinking on both ends, from which I infer that the cable is OK. The GW2 switches over to the WiFi interface and doesn't switch back. This time the IP address of the WiFi interface was different than it was originally, so DHCP must have dropped somewhere along the way. (I have now fixed the assignment to that MAC address.) A few times in the intervening weeks power has been removed from the box that is both the Ethernet switch to which the cable connects and WiFi access point adjacent to the GW2, and in all instances the GW2 continued to use the Ethernet interface. I notice that the firmware is now 21.44; perhaps it was updated last evening and that caused the change.
There have been several posts about trouble with WiFi; anyone else having trouble with hardwire Ethernet?
