H&R Block 2019 missing form 8911, again (EV Charger Credit)
Discussion in 'Electric Vehicles' started by vjason, Jan 22, 2020.
  1. vjason
    vjason Member
    Raleigh, NC
    The form: About Form 8911, Alternative Fuel Vehicle Refueling Property Credit | Internal Revenue Service
    Not even mentioned on their website: Federal Tax Form Updates for Tax Preparation Software | H&R Block®
    Anyone know if any competing products include it?
    The initial response from their support chat is:
    Since that form is not supported by our Do It Yourself products, you can file your return using our Tax Pro Review product, or at an H&R Block office.
    Looks like this happened last year too, so they may yet fix it (regardless of what support says). Support says that they will try and put in a request.
    I just can't see using a tax pro now that I don't itemize, heck it only takes 15 minutes to fill everything out.
  2. vjason
    vjason Member
    Raleigh, NC
    It appears that the IRS hasn't yet updated the form, which they last did 1/24/19. This means no program has it yet.
    H&R Block Twitter support can't say for sure it will arrive in the product, but that it could (though not until the IRS does their thing).
    So if you will be claiming it I suggest that you be patientl
  3. Stach
    Stach Member
    Madison, WI
    I decided to switch to H&R Block tax software this year because TaxAct has become ridiculously expensive and TurboTax (which I used last year) cost 50% more than H&R as well. I will be very disappointed if the H&R software doesn't support my EV credit like TurboTax did last year for my PacHy.
  4. NYCR160
    NYCR160 Member
    Mansfield, CT
    I had a similar issue last year with H&R Block. I wound up filing with them in person which you may want to consider. The 8911 form was not released at the time of my filing. Since I was getting a refund I did not want to hold it up for and undetermined period of time. Once the IRS form was available H&R supplemented the tax filing and all was good.
  5. Stach
    Stach Member
    Madison, WI
    Is it free to file in person, if you have purchased and entered all the data in the software (except for the missing 8911 form)?
  6. diamond.g
    diamond.g Active Member
    Moyock, NC
    When I filed last year I was charged for each nonstandard form.
    EDIT: I may have misunderstood the question. Can you fillout the software print the forms out and take it in person? I didn't know that was a thing.
  7. Cfy7
    Cfy7 Member
    Oswego, NY
    Just talked to Taxslayer, after using them for years. They told me they do not have the form and do not plan on adding it this year. So not them....
  8. Stach
    Stach Member
    Madison, WI
    TurboTax had the form last year.
  9. srs5694
    srs5694 Active Member
    Woonsocket, RI
    Three years ago, when I installed a Clipper Creek EVSE for the Chevy Volt I leased, it was the same story -- H&R Block didn't support the form. It was possible to fill out the form manually, from a PDF downloaded from the IRS, and then enter an override in the H&R Block software. The problem with that approach is that it then became impossible to e-file; I had to print everything out and mail it in -- for both Federal and state taxes. This worked fine, but it was an annoying extra hoop through which I had to jump. Overriding and paper filing is probably easier than going to an H&R Block office to have them do it, but if I'd known beforehand, I would have forked out the extra bucks for TurboTax that year. A friend of mine, who'd bought a Chevy Volt and an EVSE that same year, told me that TurboTax did have the form.
    I can't promise that any of this is certain to be true for the 2019 tax year, but your report makes it seem likely.
  10. linux-works
    linux-works Active Member
    mtn view, ca
    I bought the HR block fed+state from amazon via download; have not activated it yet. but from what I'm reading here, its basically NOT going to do the whole set of forms and won't efile?
    hard to believe they (tax companies) can pick and choose which forms they support! never heard of that, but never had to do more than basic tax stuff before, anyway.
    how does the 'do it in person with HR block' work if you already bought the software, but now can't use it?
    this is so messed up. its a major form! how can they justify just ignoring it? wow, just wow ;(
  11. microman
    microman Member
    Boise, ID
    Hopefully HR Block adds it.. just noticed today that the IRS updated their page to state that they are working to update the form since the law was just changed Dec 20, 2019.
    https://www.irs.gov/pub/irs-pdf/i8911.pdf
  12. Cfy7
    Cfy7 Member
    Oswego, NY
    I’ve switched to TurboTax for the year, looks like they’re going to have it this year.... once the IRS releases it.
  13. Plan B
    Plan B Active Member
    Portland OR
    It's being released Feb 5th.
  14. willow_hiller
    willow_hiller Active Member
    Maryland
    Glad I found this thread. In another about the Federal tax credit in general I posted instructions on how to file Form 8911 on TurboTax. They don't appear to have programmed the form for this year, but you can manually enter the values by using the "Tax Tools." As soon as a draft of Form 8911 is posted on irs.gov/draftforms we should be able to pick Box 7 off of that and enter it into TurboTax.
  15. willow_hiller
    Maryland
    Ah thanks. They did just add it to the list of forms coming on Feb 5: Federal Individual Forms Availability
    Hopefully they make a proper section for it, instead of needing to enter the values through Tax Tools.
  16. willow_hiller
    Maryland
    Just re-checked the link above... Both 8911 and 8936 have been pushed back to 2/12 now...
    I guess the IRS is taking their time in releasing the updates?
  17. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
  18. Plan B
    Portland OR
    ugggggggg
  19. Ferengii
    Ferengii Member
    Loveland, CO
  20. coredumperror
    coredumperror Member
    Los Angeles
    I am very confused by this form. Line 10 says "do not file this form unless you are claiming a credit on line 9", but line 9 is specifically for a "business/investment use". I installed this HPWC for my own personal use, so does this form not actually apply? Everyone seems to think it does, but the form itself seems to be saying otherwise...
    And, of course, I also use H&R Block, so they're no help.
