H&R Block At Home Deluxe 2014 & IRS 8936
Discussion in 'Off Topic' started by Atebit, Mar 2, 2015.
Tags:
  1. Atebit
    Atebit Member
    PA
    Anyone know if it's supported this year? I can't find any reliable info on their site. A search of TMC just talks about previous years...
  2. timf
    timf Active Member
    Michigan
    Yes, it's supported this year.
  3. Atebit
    Atebit Member
    PA
    Thanks Tim. I waited over 30 minutes on hold to ask this question & was told "no". So I appreciate your first-hand knowledge. I'm assuming it's available at Deluxe & above?
    This is is good news...I wasn't looking forward to switching to TT.
  4. timf
    timf Active Member
    Michigan
    I can only attest to it being there in Premium, but it appears on all published lists of supported forms that I've found without disclaimers of it requiring a certain version.
  5. Atebit
    Atebit Member
    PA
    Ah. I assumed you had the program already. I don't see Form 8936 on this list from their site: http://www.hrblock.com/pdf/TY2014-HRB-Desktop-Fed-Forms.pdf
    Where did you find it?
  6. timf
    timf Active Member
    Michigan
    Sorry, I use the online version. Perhaps it's still missing for the desktop version.
  7. morbot
    morbot Member
    Seattle
    I filed my taxes last month, I used TurboTax Deluxe Online and had no problems reporting the car. Already received my refund.
    If you're not partial to H&R Block, I'd recommend it for how easy it was.
  8. Atebit
    Atebit Member
    PA
    Thanks, maybe I'll check that out as well.
    In ithe meantime, has anyone had any luck with the at-home software version & Form 8936? At this point, I'm assuming it's not there again this year.
  9. Atebit
    Atebit Member
    PA
    Just downloaded Deluxe version for 2014 & it has Form 8936!
