Hacked? Boot me to Africa!?
Discussion in 'Model S' started by Nick Deng, May 20, 2016.
Tags:
  1. Nick Deng
    Nick Deng Member
    Temple City CA
    IMG_3534.JPG Google map reboot? and I showed up in Africa!
  2. Edmond
    Edmond Permanon
    Seattle
    Well you won't be able to charge it there. Better teleport the car back.
    • Disagree x 1
  3. Festerfeet
    Festerfeet Member
    Chengdu, Sichuan,China
    Tesla needs a different VPN server!
  4. deonb
    deonb Supporting Member
    Redmond, WA
    I grew up in that area but I've never seen the Mozambique map upside down like that.
    I think the last time I've been to Mosambique was before GPS, which would explain it, since I would have only used a North-Up map then.
    Still. It's disturbing.
  5. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Had a similar problem with my S. It would occasionally place my location as 'middle of the south Atlantic ocean'. The issue was a short in the GPS antenna. Took about 5 SC visits before they finally diagnosed the cause and fixed it, since it would only occasionally happen.
  6. Nick Deng
    Nick Deng Member
    Temple City CA
    Not just that, but due to that the scheduled 1205am charging did not work so left the car empty. Called the service support, cleared all addresses I went from the map memory, unplug all usb items and reset the infotainment center screen (program bug) to get back to normal... No teleport-(
  7. doctorwho
    doctorwho Active Member
    Eurobin, Victoria. Australia
    Thats when you need to enter the 007 code and turn the car into a Bond submarine
  8. Nick Deng
    Nick Deng Member
    Temple City CA
    Map getting slow when more places I go, big ipad loading slow, web slow... the system maybe made cheap, no as good as the real ipad... Linux code base, bad memory flash code etc.
    • Disagree x 1
  9. MorrisonHiker
    MorrisonHiker S 100D 2019.16.2
    Colorado
    @Bjorn did a video showing how clearing out the previous destinations will speed things up again. Hopefully they will add a Delete All option one of these days.
  10. LegalCounsel
    LegalCounsel Member
    EU
