Daniel in SD
(supervised)
I mean width. Looking at the picture of the P it sure looks like the tires are the same width as the LR. 20" wheels are just for looks and to fit bigger brakes. If they wanted to make it competitive with the BMW M3 they would have to give it a wider track to fit wider tires. That would require changes to the suspension. It would also require wider fenders.I'm not sure I understand what you mean by the wheel size being the same? I'm assuming you mean width?
~$25k is a lot of play room for simply "more capable" inverters and motors, and bigger brakes. We also only know what size tires were offered with Tesla website 20" Sport wheel combo, and not what is finalized for the Performance Model 3. Seems like stiffer springs and ARBs with revised dampers would be a no brainer to improve performance, particularly if the target is better than BMW M3 performance in more than a straight line. The 4S tires are significantly more capable than the 18" Michelin Primacies and a good margin better than the 19" Contis. Didn't the P (non-D) Model S's that first came out have stiff suspension setups? Its not like they have done it before. They just have a much more capable chassis now in the Model 3.
I think the Tesla customer is very different from the BMW M customer. People are perfectly happy with the P100D even though the suspension is exactly the same as the 100D. The P85+ had stiffer suspension but there's probably a reason they stopped making it.
