jacobp Member Aug 30, 2013 345 51 Potomac, Maryland, United States Sep 15, 2013 #1 Sep 15, 2013 #1 Other than a plastic hose reel (which may be the best solution), how else are you storing your charging cable?
S spaghetti Member May 10, 2013 299 37 Silicon Valley Sep 15, 2013 #2 Sep 15, 2013 #2 jacobp said: Other than a plastic hose reel (which may be the best solution), how else are you storing your charging cable? Click to expand... I use a cheap broom / mop holder - works like a charm. This is the one I use: Amazon.com - Wall-Mounted Tool Rack/Broom and Mop Holder
R rlang59 Member Feb 27, 2013 945 30 US Sep 15, 2013 #3 Sep 15, 2013 #3 There is a thread here : http://www.teslamotorsclub.com/showthread.php/12589-Storing-your-UMC that shows what a lot of people are doing.
ElSupreme Model S 03182 Moderator Jan 13, 2012 4,303 108 Atlanta, GA Sep 15, 2013 #4 Sep 15, 2013 #4 I actually set mine on a shelf.
Amped_up Member Sep 3, 2013 39 0 San Antonio, TX Sep 15, 2013 #5 Sep 15, 2013 #5 I installed the Gladiator wall tracks for my other garage items. Its right above where I put the outlet, so I use a Gladiator hook.
bareyb Active Member Sep 2, 2013 1,187 83 Silicon Valley, CA Sep 15, 2013 #6 Sep 15, 2013 #6 rlang59 said: There is a thread here : http://www.teslamotorsclub.com/showthread.php/12589-Storing-your-UMC that shows what a lot of people are doing. Click to expand... Thanks. - - - Updated - - - spaghetti said: I use a cheap broom / mop holder - works like a charm. This is the one I use: Amazon.com - Wall-Mounted Tool Rack/Broom and Mop Holder Click to expand... Thanks.
Bound466 Member Dec 31, 2011 221 24 Rancho Cucamonga, CA Sep 15, 2013 #7 Sep 15, 2013 #7 Good ole' plastic hose reel. Does the trick and still looks nice.
bareyb Active Member Sep 2, 2013 1,187 83 Silicon Valley, CA Sep 15, 2013 #8 Sep 15, 2013 #8 I think I'm leaning towards getting the $25.00 version from Tesla. From what I read, it works with the standard charger cable too. Shop Tesla Gear Replacement High Power Wall Connector Cable Organizer Attachments Wall Connector Cable Organizer.png 329.1 KB · Views: 655
Lump Active Member Mar 31, 2013 2,618 2,632 So. Cal. Sep 15, 2013 #9 Sep 15, 2013 #9 Not the prettiest but working good so far...
S spaghetti Member May 10, 2013 299 37 Silicon Valley Sep 15, 2013 #10 Sep 15, 2013 #10 Lump said: Not the prettiest but working good so far... View attachment 30677 Click to expand... This has to be one of the more creative solutions, what with the "wall plate" around the plug and the bungee cords :smile:
Larry Chanin President, Florida Tesla Enthusiasts Moderator Aug 22, 2011 4,937 814 Sarasota, Florida Sep 15, 2013 #11 Sep 15, 2013 #11 jacobp said: Other than a plastic hose reel (which may be the best solution), how else are you storing your charging cable? Click to expand... A metal hose reel. :wink: Larry
ToddRLockwood Active Member Sep 11, 2012 1,318 92 Burlington, Vermont Sep 15, 2013 #12 Sep 15, 2013 #12 jacobp said: Other than a plastic hose reel (which may be the best solution), how else are you storing your charging cable? Click to expand... ~$5 at Home Depot
JPP Active Member Feb 4, 2013 3,088 1,355 SF Bay Area, CA Sep 15, 2013 #13 Sep 15, 2013 #13 I use a central vacuum hose hanger (plastic) which allows me to hang the UMC tote bag and adapters. Got mine at: www.builtinvacuum.com
cfOH Member Jul 1, 2013 103 6 Cincinnati, Ohio, USA Sep 15, 2013 #14 Sep 15, 2013 #14 Here's a link to my write-up on the cable setup I rigged in our garage: https://plus.google.com/u/0/103183570053193175186/posts/6rbgJpGupam It's not pretty, but it's really convenient and easy-going on the cable itself (I think).
M MarkR Member Mar 24, 2012 893 7 N. Scottsdale, AZ Sep 15, 2013 #15 Sep 15, 2013 #15 Why bother with anything other than a garden hose reel . . . Simple . . . Cheap . . . Easy to install . . . Works perfectly!
