Hannibal, MO needs a Supercharger
Discussion in 'Midwest/Great Lakes' started by ratsbew, Aug 17, 2019.
  1. Jdulle
    Jdulle New Member
    Cedar rapids
    You are correct, it was the filters. Thank you!
  2. EAdair
    EAdair New Member
    STL
    Have you, or anyone else, used the CHAdeMO charger here? My chargepoint app only shows the j1772 chargers (at a reduced capacity, no less ).
  3. mociaf9
    mociaf9 Active Member
    I don't live in the area and haven't driven through Canton, so I haven't used it. But others have. You can see multiple check-ins on Plugshare from people with native CCS or CHAdeMO cars and also by Tesla drivers that had to use a CHAdeMO adapter. The most recent check-in was from a Leaf driver successfully charging via CHAdeMO two weeks ago (in mid-February). As for not seeing the location on your ChargePoint app, I'll repeat what I said in the message you replied to: check your filter settings and be sure that you have enabled the display of DC-CHAdeMO stations under Connector Type.
