Hansshow Audio Upgrade? (SR+)
beachsideev
276
134
usa
I have a June ‘20 model and have the rear speakers. Out of curiosity what month/year is yours?
the sticker on the driver's door jamb say 02/20 and it appears that I have speakers, but it is hard to tell. I think I can make out rubber surrounds and the voice coil dome through the grills.
If I didn't have those speakers I'd probably pass since my biggest complaint with the sr+ audio is the lack of bass. I don't expect the rear shelf speakers to replace a sub, but they might help a little.
InfinitySky
42
17
Oregon
That is my concern as well that the ICE can handle it all the speakers. It sounds like it can as long as you aren't cranking the volume/bass. I am just curious what the sound quality is after the install of just the harness.
I’m concerned about this as well. It’s even mentioned as a potential issue in the Tesla Offer install video. I’m curious as to what “cranking the volume/bass” actually would mean in practice. I have my bass at +4 and don’t generally turn the volume over 50%. I’m assuming this would be fine?
InfinitySky
42
17
Oregon
I’m actually starting to 2nd guess if I even have these as well. I looked on the top behind the backseat and it looks like they are there...but based on my delivery date I don’t think I should have them after listening to what others are saying. Is it possible it’s just a shell of a speaker and it’s not actually there?
beachsideev
276
134
usa
the speaker grills are there but there may be nothing behind them.
beachsideev
276
134
usa
this is what it looks like behind my grill:
that looks like a speaker to me.
Reactions: strykeroz
HitUpOlas
71
43
Atlanta
If you have the solid grill that goes across you are guaranteed to have the rear speakers. My late AUG 2020 build has two grills but no speakers. So I bought a 2018 rear deck.
Another way to check: pop off the trim piece on the passenger seat back, next to the door. There is a white square connector there. If the wiring heading to your rear deck only has 2 wires (3rd brake light) then you don’t have the speakers or wiring needed. If it has 6 you are good to go.
beachsideev
276
134
usa
Well I bought the diy version. at least I think I did because the page closed after checkout but I haven't gotten a confirmation email. worst case I'll sell it here if I don't want to install it.
beachsideev
276
134
usa
do you have a picture of the solid grill? I have 2 separate grills on each side right at the base of the rear window.
InfinitySky
42
17
Oregon
Thanks for the info...I don’t have the solid grill all the way across (I think?) so I probably don’t have the speakers. Where did you buy the 2018 rear deck and did you install it yourself?
This is quickly turning into a more expensive and complicated mod :(
HitUpOlas
71
43
Atlanta
Here are some pics of the 2018 rear deck I have taken apart. Going to install the speakers and harness into my 2020 rear deck. Looking to get the $700 Hanshow in a little bit.
HitUpOlas
71
43
Atlanta
Here is a picture of the other side. I placed the grill in front of where it normally would sit. Got mine off eBay for less than $200. Going to swap the 3rd brake light as well since it has the foam piece around it that keeps the reflection of the brake light from being seen in the rear window.
sparkz
40
15
I ordered the $80 DIY version. I didn’t get a confirmation email either. Too bad I didn’t see that other 10% off beforehand. I have two rear shelf speaker grilles on my Mar 2020 M3 SR+. Shining a light through the back window I can see a speaker.
Looking underneath the shelf you can’t tell as there’s a bump but it is all closed up (unlike the photos above).
Note the Hansshow one includes a box to resolve the impedance issue and act as a crossover to filter the right frequencies. Hope it does. TeslaOffer don’t have that.
(Edit: Specifically, my car was delivered 1 Mar 2020, so it is a Feb build)
jaredg19
46
15
Vancouver
I'd be interested in the professional version, but not if my Model 3 doesn't have the rear shelf speakers. I have either an Aug 20 build I believe.
Hayden
1,243
545
Belgium
Just shine a bright light through the window and you will see the speakers through the grille. With me they are in it, September 2019.
