Hansshow Audio Upgrade? (SR+)
Jun 13, 2019
54
143
BC
there is currently a 10% off using the code DTCspeaker
Unless you are really cranking the volume, I think the amps will be fine.
Awesome, thanks! I was on the fence about the Professional package but the 10% off sealed it!
Looking forward to hearing (haha) your guys impressions after you get it installed.
sa012
187
45
Central CT
Just order the DIY harness and will give it a shot. $72 bucks is worth trying. Installation looks pretty easy. Just hoping sound quality is there using the ICE amp.
InfinitySky
42
17
Oregon
I’m seriously considering installing the harness even though I don’t have the back speakers. Does anyone have any thoughts on this? Also, what tools will you be using to take off the panels to install?
I’m thinking the back speakers are mostly for the rear passengers anyway and I don’t care as much about them as the driver (me). Selfish, I know, but it’s true ;)
beachsideev
276
134
usa
If I didn't have the rear speakers I'd probably pass.
As for tools, my plan is to use my trim removal tool set. You can pick them up at harbor freight for a few bucks.
jaredg19
46
15
Vancouver
The rear speakers are definitely not for the backseat passengers. They provide a surround sound effect.
Just doing the front isn't worth it at all. It'd be like having only a center channel speaker with your Home Audio set up. Which isn't how music is meant to be listened to!
B.K.
20
Bay Area, CA
I’m also leaning towards the DIY kit but want to get some reviews from the group if there’s a noticeable improvement. Also am curious if the speakers inside are also used when the alarm goes off and the implications if any if the additional speakers are connected.
InfinitySky
42
17
Oregon
I see your point, but isn’t only having a center channel speaker exactly what I have right now? The harness would still help with the surround effect on the sides, correct?
sparkz
40
15
It might be worth ordering the speakers. There’s a part number in that teslatap link on the first page of this thread. Of course you might need a few wires from those speakers to the plug in the harness at the rear side, but it shouldn’t be super-hard to do.
InfinitySky
42
17
Oregon
Thanks for the info, and I could see how this is worthwhile, but I can’t seem to find the part # on that TeslaTap page. I see where it says that the rear consists of 2 4” midranges, but when I scroll up to the “speaker components” (where the part # should be) I don’t see anything for those midrange speakers. Am I just missing it?
sparkz
40
15
it says 4” mid range rear. Above that is this part number, which would be my guess:
full range 1079742-00-A 4” (100 mm) 3 ohm 33 W
seems like they are the same as the ones in the front dash perhaps:
Everything I've been able to gather about the Model 3's audio system : teslamotors
Looks like around $50 each on eBay though.
InfinitySky
42
17
Oregon
Yeesh...and of course currently sold out even if I wanted to purchase. Having never even installed these I’m not even confident I could get the wires set up correctly without a step-by-step video as well.
Thanks for the info but now I’m looking at $200 plus even more work/labor to try to get those things installed. That’s a tough one for me to justify
todd2fst4u
188
128
Menlo Park
I put together a plug and play premium audio upgrade. Includes an amplifier to power the 4 front tweeters and 2 rear dash speakers. Plus the OEM 8” subwoofer.
