Hansshow Audio Upgrade? (SR+)
I don’t believe you are correct. The SR/SR+ main computer outputs a center channel. The center tweeter is hooked up to the center channel speaker.
Do you own a SR? Or will you take advice from an actual SR owner who had the SR+ configuration before they nerfed it? My EQ settings had to change after my car showed as a SR -- immersive off before too. I had to bump up the trebles to get it to sound similar to before.
Reactions: cdswm3
You are correct. The SR has the center tweeter disabled as it only works with immersive sound.
Audio Systems for the Model 3 – TeslaTap
