Hard Top Question
Discussion in 'Roadster 2008-2012' started by Pantera Dude, Mar 18, 2012.
Tags:
  1. Pantera Dude
    Pantera Dude Member
    Long Beach, California
    Since I don't see many Tesla's running the hard top, I presume they were not included with the car? If not, what do they cost?
    Thanks
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    My (painted) hard top was CDN $3670 (clear carbon fiber would have been $5,735). The US prices were slightly lower.
  3. NigelM
    NigelM Recovering Member
    Northern Virginia
    Mine was $3,200, but they didn't have the color in stock so it took about 14 weeks. Also note that you need to have Tesla fit it the first time as they have to do window adjustment; I don't know if/what they would charge for that as I got mine fitted as part of the annual service and they didn't charge me for that part of the work.
  4. ViperDoc
    ViperDoc Roadster 1305
    Vermont
    My recollection is that my carbon fiber hard top was about $5000 when I purchased my car last summer. I swapped onto the car myself and didn't need any adjustments. I nearly took it off today with the warm weather here in VT this weekend, but I decided to hold off until it was really summer and not just faux summer!
  5. Doug_G
    Ottawa, Canada
    Heck, I'm in Canada and I took the top off today! Unbelievable weather. Broke the previous record by 8 degrees C (14F).
  6. NigelM
    Northern Virginia
    I bought mine to protect me in the summer!
  7. Pantera Dude
    Pantera Dude Member
    Thank you guys! The cars do come with a soft top, correct? Is it water tight? Any idea how much weight savings there is between the carbon fiber top and the standard steel, aluminum, fiberglass top?
  8. NigelM
    Northern Virginia
    Apparently (Tesla says) there's no significant weight difference between CF and painted hard tops; but that's never been confirmed with data AFAIK.
    The soft top is waterproof, but in heavy rain there is a tendency to leak around the top of the doors and it will drip down onto the door sill and your pants when you open the door to exit/enter.
  9. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    It was confirmed by Tesla employees in Menlo, who directly weighed both kinds of tops when I asked. I wasn't there when they did the weighing, in case you want to continue the conspiracy. :wink:
  10. Doug_G
    Ottawa, Canada
    You misunderstand. Both hard top options are CF; the difference is whether it's painted or clear carbon.
    As for the soft top, yes it is included. It's quite water tight, although I'm told you might get a tiny bit of leakage in hard driving rain. (As it happens I've yet to encounter a nasty thunderstorm except when I happened to have the hard top on.)
  11. Dragon
    Dragon Member
    Italy
    Had the soft top on with every kind of weather, including extreme rain where you are unable to drive. No leaks.
  12. tennis_trs
    tennis_trs 2010 2.0 Roadster Sport
    My hard top is 10 pounds lighter than my soft top (as accurately as I could measure):
  13. user497
    user497 Member
    I had my Roadster for 2 years without a garage and never had a problem with the soft top leaking (I had the soft top on from end of March to end of November and the hard top during the winter). So the problem for me wasn't when the car was sitting in the rain. However, the water does tend to drip on the door sill when you open the door and it is raining. That's my experience but it sounds like it varies slightly from car to car.
  14. Pantera Dude
    Pantera Dude Member
    Thank you guys for all the info!
