Hard wire radar detector
DtotheW
24
10
Sunnyvale, Ca
1st I've read all the forums regarding hard wiring. So far I haven't seen any info on anyone being successful at hardwiring a radar detector. I saw that there's no "customer" 12V power available like in the M3. Just want to know if anyone's cracked the code on this. I want it wired so that it goes off when I'm not driving the car. Thank you.
Watts_Up
3,094
2,053
In a galaxy far, far away
Thank you.
Did you look at 12v Switched?
DtotheW
24
10
Sunnyvale, Ca
I just had another idea, let me know what you guys think. Can I hardwire to the back of the cigarette lighter adapter? Then just manually turn off the radar detector when not in use. I have the hardwire kit with built-in fuse.
DtotheW
24
10
Sunnyvale, Ca
I don't have my car yet but how about taping into the fuse box like every other car.
Yeah there's no clear guidance on this yet. There's no 'customer' fuse box like any other car and it's also not like the M3 is set up. I think the best game plan is to hard wire to the rear view mirror (if that's your thing, I'm not going this direction) or mount behind the screen with the wire routing down through the center console, hardwired to the back of the cigarette lighter. I think it'll be 'always on/hot' so you'll need to manually turn off your detector.
For those of you following, I did test to see if the car would auto off the cigarette lighter as I had the radar detector plugged in and I left it for 30 minutes... Still on.
acevasio
New Member
Mar 19, 2020
2
0
New Jersey
What detector do you have? I have a Valentine 1 gen 2 plugged into the 12v cigarette lighter in the center console and it auto powers off when I exit the car at pretty much the same time the screen goes dark.
DtotheW
24
10
Sunnyvale, Ca
I've got the Valentine 1 Gen 1. That's interesting. I'm wondering if it's a gen 2 thing. Does your cigarette lighter plug have a red led? I'm wondering if it remains on.
mswlogo
5,965
4,572
MA, NH
I tapped the power going to the rear amp on the Model 3. Bet you can do the same thing. You can also tap the cigarette lighter socket. I’ve tapped the mirror easy on Model X.
acevasio
New Member
Mar 19, 2020
2
0
New Jersey
It does have a red light.. I'll try to figure out a way to see if it stays on tomorrow. Curious to see if it's draining battery now.
