Hardware changes
Discussion in 'Model S' started by brianman, May 29, 2013.
Tags:
  1. brianman
    brianman Burrito Founder
    #1 brianman, May 29, 2013
    I don't recall seeing a thread for collating pictures of various hardware changes. Perhaps we should start one. Or maybe a wiki. For now, I'll try a thread and see what the mods think.
    Changes that were discussed, but I can't find the threads. Please PM me if you find the pictures (or have some available):
    • Trunk footwell cover
    • Fog lights (and/or cornering lights)
    • Visor mirrors
    • Continental vs. Michelin (21" tires)
    - - - Updated - - -
    Left is my original (U.S.) Signature vehicle J1772 Adapter.
    Right is the updated one that I picked up today.
    TSL02 to J1772 ADPTR
    P/N: 1005617-00-A
    S/N: T1200000446
    DO NOT USE IF DAMAGED
    ENCLOSURE: TYPE 4
    CAUTION - NOT FOR CURRENT INTERRUPTING
    TEMPERATURE RATING: -22F(-30C)~122F(50C)
    INPUT & OUTPUT: 240VAC, 50~60Hz, 80A MAX
    READ OWNERS MANUAL BEFORE OPERATING
    TESLA MOTORS, INC. PALO ALTO, CA 94304
    P/N: 1005617-00-B
    S/N: T1300023806
    ENCLOSURE: TYPE 4
    Functional differences reported by Tesla:
    1. Better fit for the broad array of J1772 EVSEs in the marketplace.
    Observed differences:
    1. P/N change from 1005617-00-A to 1005617-00-B.
    2. Newer one is shinier.
    3. Color change from gray to bluish gray.
    4. Triangle-with-exclamation icon next to the "CE" logic changed from yellow to white, and no longer has an inset black triangle.
    - - - Updated - - -
    Floor mats (original)
    Floor mats (retrofit)
    - - - Updated - - -
    Cupholders original
    Cupholders variation 1
    Resized version of the attachment here:
    Cup holder cinchers
    - - - Updated - - -
    14-50 UMC Adapter
    • TPN Old: ?
    • TPN New: 1014324-00-B
  2. Galve2000
    Galve2000 Member
    NYC
    A Bit OT but...
    Can anyone confirm if the J1772 adapter is rated for 80 amps? i'm installing a Clipper Creek CS-100 in my summer home and would like to be able to use it with my Twin Charger Model S when it arrives. Wether or not the adapter can handle 80 amps has been a concern of mine.
    Thanks in advance for taking the time to reply.
  3. deonb
    deonb Supporting Member
    Redmond, WA
    See picture above... (3rd line from bottom).
  4. Musterion
    Musterion 18h 03m 37s −24° 23′ 12″
    M8
    Well if you take a look at the photo @brianman posted above, both stickers show a rating for 240VAC at 80A max...
  5. ddenboer
    ddenboer MODEL X #1770
    Austin, TX
    Apparently the original ones were hand-made in a small batch, and the new ones are molded plastic. The original ones were susceptible to expansion under extreme temps.
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I've been testing a CS-100. Several Model S's have used it including mine, and no one has melted an adapter yet. Doesn't even get warm.
  7. MikeC
    MikeC Active Member
    Los Angeles
    Was the new one free? Or do you have to trade in the old one?
  8. brianman
    I've added a table to the OP that includes the old and new text. The changes are in red.
  9. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    They took my old one away when I went in for service last time and didn't give it back. Kind of wish they'd let me keep both.
  10. brianman
    I asked. :) I should have asked to keep the 14-50 adapter but I suspected they wanted to keep those, since they present a hazard (melting) whereas the old J1772 issue was just annoyance.
  11. lolachampcar
    lolachampcar Active Member
    WPB Florida
    another data point. I routinely charge at 80 amps with my OpenEVSE and Tesla 1772 adaptor with zero problems.
  12. NigelM
    NigelM Recovering Member
    Northern Virginia
    Back on topic, I can think of a few hardware changes but I don't have photos:
    • Fog lights
    • Carpets
  13. brianman
    #13 brianman, May 29, 2013
    Updated OP.
    Added to TODO list in OP.
  14. spatterso911
    spatterso911 MSP#7577 **--** MX#1891
    Rancho Cucamonga, CA
    Visor mirrors
    Tires - Conti vs Michelin
  15. DFibRL8R
    DFibRL8R Active Member
    Leesburg Virginia
    Saw a newer model S with different cup holders than mine. My cup holders have spring-loaded grips/prongs that help grip the cup. Saw a newer version that was just a smooth holder without the spring grip.
  16. brianman
    Updated OP.
    - - - Updated - - -
  17. spatterso911
    Visor mirror now glass instead of plastic
    Fog lights present
    Fog lights absent
    - - - Updated - - -
    Defroster grill
  18. ChadS
    ChadS Petroleum is for sissies
    Early cars - when they got parcel shelves at all, which it appears very few did - got a tri-fold unit. Pictures HERE. Now they ship out ones where the rear half just flips up.
  19. brianman
    There's also the "with metal" and "without metal" (relates to the magnetic snapping).
  20. FlasherZ
    The defroster grille still isn't a standard item... the P85+ in the Santana Row showroom last week didn't have them. i think they're "cold weather only" options installed by service.
