Has Anybody Tied In To 12 Volt System
Discussion in 'Roadster 2008-2012' started by Botbldr45, Nov 10, 2013.
Tags:
  1. Botbldr45
    Botbldr45 Member
    Sedona, Az
    I was wondering if anybody has used the 12volt system in a roadster for an accessory add on. If so, where did you gain access? How many times did you blow a fuse? Any information would be greatly appreciated
  2. augkuo
    augkuo Member
    Berkeley
    I had my subwoofer amp powered from the 12V accessory outlet. Just make sure you don't go over 125 W ;)
  3. Botbldr45
    Botbldr45 Member
    Sedona, Az
    Thanks for the information.
    Did you wire into the plug or just plug in to the socket?
    125W is the limit before popping the fuse?
  4. augkuo
    augkuo Member
    Berkeley
    I wired into the plug - the manual says 125W is the limit (page 7-6) but it's got a 15A fuse so it'll blow after 180W.
