I'm trying to class my RWD Model 3 to participate in an upcoming Time Trial event with NASA. The classes are primarily based on Wt/HP ratios with adjustments for modifications. Based on the guidelines, my LR RWD would fall into Class 5 with a ratio of 14.13. NASA ST/TT Car Classification Form.
But, that is based on an average HP of 283, (Tesla Model 3 - Wikipedia) which has to be verified with Dyno results. It is hard to know for sure as the guidelines for determining average HP are fairly complex.
"Avg HP = Average HP calculated and used in the Adjusted Wt/HP Ratio The following sixteen (16) data points will be obtained from the Dyno’s 50 RPM data export numeric RPM/HP table printout: Horsepower at: 250 rpm, 500 rpm, 750 rpm, 1000 rpm, 1250 rpm, 1500 rpm, 1750 rpm, 2000 rpm greater than Max HP rpm Horsepower at: 250 rpm, 500 rpm, 750 rpm, 1000 rpm, 1250 rpm, 1500 rpm, 1750 rpm, 2000 rpm less than Max HP rpm (If any of the above data points at higher RPM than Max HP RPM do not exist due to redline, then those potential data points will not be used in the calculation of Avg HP.) For vehicles with a redline greater than 7000 rpm: The seven (7) highest data points of the above sixteen (16) will be used in the calculation below: Avg HP = (Max HP +(sum of the seven highest data points)) divided by 8."
Before I go too much further with this, I'm wondering if anyone has already gone through the process of getting their Tesla officially classed. Also, I've read through the rules and don't see anything that specifically disqualifies an EV, but there are a lot of details that I may be overlooking.
Thanks for any help!
