Stellavator
I suspect there must be some range hit. Maybe not big, but those wheels were inset by design for aerodynamics. Can anyone out there get any sense for a real world difference? I'd really like to do this mod.
Here's a picture to explain what I mean.
The rear have one nut, so I'd use the OEM nuts to attach the wheel to the spacer.
Do I have to use the provided regular nuts for the fronts? Or can I use the OEM ones?
(I assume you also just toss away the rubber black protectors that came on the rear spacers)
No, you wouldn't use both the way you described. You use the rounded ones to attach the spacer to the hub. And the other ones to attach the wheel to the spacer.Wait... why would you put two nuts on of the the front lugs in the first place? Sounds like a poor design.
Oh, ok, gotcha...No, you wouldn't use both the way you described. You use the rounded ones to attach the spacer to the hub. And the other ones to attach the wheel to the spacer.
Why anti-sway bars? Are they needed for this mod?My next purchase will be the anti-sway bars both front and back from Unplugged Performance. That will be it.
Fred
Will this have any effect on wheel alignment, camber/toe, tire wear, suspension performance, etc...?
Thanks. Want to do this, but can't find any way to know if this is minor enough to not cause problems. There are definitely effects on suspension dynamics. Just don't know if significant.The offset is minimal (15 mm front, 20 mm rear), I doubt it would have any negative measurable effects to the things you listed.
No, the sway bars are for stiffer cornering. Has nothing to do with this mod.
Installed the spacers last week. LOVE the new look. Much more sporty-looking. Before and after pics below (sorry, couldn't get the exact same angle in the two pics).
This is the only one I've got on my phone right now...Would you mind posting a few more pictures a bit further away? Thank you! Looks great. I'm definitely considering this.
I can tell you that the sides of the car get disgusting (especially the passenger side). Below is an example.Can you show pics of how dirty the car gets without mud flaps, and a pic of the car with mud flaps installed? Wonder what the efficiency hit is for this mod, and then combined with the added drag of the mud flaps?
